Archive7
Interesting thread. Here is mine at last
What type of connection is that? Cable? VDSL? Mobile? From the ISP name it sounds like a cable company.![]()
Better late than never!![]()
Yes VDSL.What type of connection is that? Cable? VDSL? Mobile? From the ISP name it sounds like a cable company.
Edit: I guess VDSL, as I just found their website.![]()
Thanks for answering, @Milamber i will try the quite line test again, and if I get the same result, then I will raise it as fault on the phone line.OK, the polarity should not really make any difference at all, but in the old days when I was there, white would be the primary connection, so white to A and orange to B, stems from the days we had white/blue, white/orange, white/green etc.
However, I doubt this is the problem at all. The " shhhhh " sound you can hear in quite mode, ie with phone mike muted, is indicative of a " hr " earth contact on the copper feeding to the house. This is unlikely to be on the " drop cable " as you put it, ( dropwire in old BT speak ) but more likely the connection on the distribution point ( DP ) Primary Connection Point ( PCP ) also known as a cab ( short for cabinet ) or Secondary Connection Point ( SCP ) also called a pillar. ( Them weird looking "stone" coloured posts you all look at, and wonder what they are ) or more likely in an underground joint in the cable ( AKA wet joint )
If your internet provider is sure they are not to blame, ask them to ask BT ( Open wretch ) to investigate for line contacts.
Best I can advise without access to the LTS from the local exchange!
Is the NHS walk in centre still open?And there has been an update from open leach, a problem has been found at my node
You might have to speak up a bitI've got some String unravelled and waiting.
Pardon, is your string wet?You might have to speak up a bit![]()
