Trust
- Jul 18, 2004
- Age
- 77
- 1.8 m CM at SMR 1224 + Elev. with 7 lnb changer Ku (lin - circ) - Ka (lin - circ) C (lin - circ)
- Nijmegen Netherlands
Thats correct , for your location 52º N / 4.7º E , at Usals the motor turns to 0.11º E for sat 4.8º E and to 9.14º E for Hotbird 13º E .The LNB satellite and motor are set to approximately to the south. Since I read everywhere that if u use USALS u don't need to to set everything exactly to due south, that's why I don't aim to due south either and I don't know due south at my location either.
I did reset the motor and the receiver and entered the coordinates again, this didn't solve the problem. When I took off the motor from the pole and directly connected it to the receiver, I played around a bit with entering different latitude and longitude numbers. I changed the longititude to zero and typed in like 80 as my latitude then the deviation on the motor reduced to around one degree.
When I finally entered my exact coordinates again, it went crazy again cuz when I select Goto 0 it goes to 1.0eEast and then I entered 4.8East it just stayed at 1.0East and like it went to 10east after I entered 13east.
Nothing wrong with that .
