French FTA's 5w 9e after april 5 ?
Adam792
Cheltenham
Yes I noticed this evening too! Even stronger than 12648V for me now.
Sent from my iPhone using Tapatalk
MCelliotG
Thessaloniki, Greece
Confirmed! The signal levels on 11509H seem to have got back to normal for two days now, in fact this frequency comes now a bit stronger than 12648V.
VodzigorLans
Setup is down atm
RU, Saint Petersburg
11554V all test cards are gone, only 3 promo are there so 50mbps is spare. Any ideas or insider information what that tp is going to be used for?
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
CHANNEL
Name: "Nameless 11554_301"
TRANSPONDER
11554, V, 29950 8PSK FEC 3/4
5.0°W (3550 - Eutelsat 5 West A)
IDs
NetwordID: 0 TransponderID: 20300 ServiceID: 301
PIDs
Video: 611(H.264) Audio: 612 - fra (E-AC3)
Audio: 613 - qaa (E-AC3)
Audio: 614 - qad (E-AC3)
PCR: 611 PMT: 610 Teletext: 0
CHANNEL
Name: "Nameless 11554_302"
TRANSPONDER
IDs
NetwordID: 0 TransponderID: 20300 ServiceID: 302
PIDs
Video: 621(H.264) Audio: 622 - fra (E-AC3)
Audio: 624 - qad (E-AC3)
PCR: 621 PMT: 620 Teletext: 0
CHANNEL
Name: "Nameless 11554_303"
TRANSPONDER
IDs
NetwordID: 0 TransponderID: 20300 ServiceID: 303
PIDs
Video: 631(H.264) Audio: 632 - fra (E-AC3)
Audio: 633 - qaa (E-AC3)
Audio: 634 - qad (E-AC3)
PCR: 631 PMT: 630 Teletext: 0
CHANNEL
Name: "Nameless 11554_304"
TRANSPONDER
IDs
NetwordID: 0 TransponderID: 20300 ServiceID: 304
PIDs
Video: 641(H.264) Audio: 642 - fra (E-AC3)
Audio: 644 - qad (E-AC3)
PCR: 641 PMT: 640 Teletext: 0
CHANNEL
Name: "Nameless 11554_305"
TRANSPONDER
IDs
NetwordID: 0 TransponderID: 20300 ServiceID: 305
PIDs
Video: 651(H.264) Audio: 652 - fra (E-AC3)
PCR: 651 PMT: 650 Teletext: 0
CHANNEL
Name: "Nameless 11554_306"
TRANSPONDER
IDs
NetwordID: 0 TransponderID: 20300 ServiceID: 306
PIDs
Video: 661(H.264) Audio: 662 - fra (E-AC3)
Audio: 663 - qaa (E-AC3)
PCR: 661 PMT: 660 Teletext: 0
CHANNEL
Name: "Nameless 11554_307"
TRANSPONDER
IDs
NetwordID: 0 TransponderID: 20300 ServiceID: 307
PIDs
Video: 671(H.264) Audio: 672 - fra (E-AC3)
PCR: 671 PMT: 670 Teletext: 0
info from www.satindex.de
VodzigorLans
Setup is down atm
.... Some channels appeared... no idea what is going on... real channels are encrypted...:(
NIT: 5.0W 11.554 GHz Vertical 29950 3/4 8PSK (DVB-DSNG/Turbo/DVB-S2)
PMT PID 610 (0x0262) - Program 301 FRANCE 2 HD
PMT PID 620 (0x026c) - Program 302 FRANCE 3 HD
PMT PID 630 (0x0276) - Program 303 FRANCE 4 HD
PMT PID 640 (0x0280) - Program 304 FRANCE O
PMT PID 650 (0x028a) - Program 305 franceinfo:
PMT PID 660 (0x0294) - Program 306 CANAL+ HD
PMT PID 670 (0x029e) - Program 307 LCI
PMT PID 680 (0x02a8) - Program 308 service_interactif
PMT PID 100 (0x0064) - Program 321 FRANSAT INFO
PMT PID 240 (0x00f0) - Program 322 FRANSAT INFO HD
PMT PID 250 (0x00fa) - Program 323 beIN SPORTS ACTU
PMT PID 890 (0x037a) - Program 894 SSU vEOXHD
Apparently the fta French stuff on 5W 11591V is being shut down leaving just the multi streams & scrambled stuff.
That's a shame ......SWMBO often watches those.
Nah, just a shift of the offset LNB.
Her dish points to 13E, with a Monoblock for 13E and 19E, with a cheapo bracket to allow an offset LNB at 5W.
Might struggle to physically fit the same LNB at 9E, so either an Alps required or I'll whack on the spare Motor instead ;)
4wd
Getting the picture
5 W, 9-13-19-28 E
VodzigorLans
Setup is down atm
As i understand GR1 is moving into 11509H so they dont want to pay for 11591V. Well that is sad since other provider doesnt want to make it FTA. I know and i also read a lot people like to watch those fta pack, some people get it at one lnb with 4W, in my city French speaking people have dishes especially for fta national France channels.
Buy a card since it most likely is able to work with your reciever with some tricks. )
I would recommend you do that. For me sometimes Fransat freuencies have errors in streams which causes glitches, i dont know why it happens... signal always stable arount 15db but multistream frequencies are fine.
4wd
Getting the picture
5 W, 9-13-19-28 E
^^^ Thanks for reply. I'd rather not get (back) into fixes and wizardry, so it's either a Fransat receiver or 11509.
Sad that ci+ is not an option for the vu+. Will let the matter rest for a while and read \ think :O)
If your tv has a CI+ slot & satellite tuner just get the fransat CI+ module & card &connect the 5w dish direct to the tv.
4wd
Getting the picture
5 W, 9-13-19-28 E
^^^ A tv with sat + ci+ (current tv got none) is an option I've been thinking about, am sceptical of' what could be 'jack of all trades\master of none' equipment. Looks like just a few sat-tv's available, expensive, and got no idea of the sat receiver quality\support. But keeping the door open.
Most LG's seem to have a satellite input, although its not mentioned in the UK advertising
VodzigorLans
Setup is down atm
Are you sure that will work? As far as i know Fransat cam is hardware blocked and work only with ceratain hardware. At least it doesnt work with my receiver so i have to use 'card readers' to make it work.
No idea - does anyone have a tv with a sat tuner & a ci+ slot that can test it for us?
4wd
Getting the picture
5 W, 9-13-19-28 E
Found LG's, indeed many more models than I thought. But quite high prices for the larger models... Basically, I could buy a Fransat box + a vu duo2 + a decent 40" (+ motorize my 125cm) for approx the same price as one s2 equipped 'smart' lg available here!
Adam792
Cheltenham
The Fransat CAM will work in any CI+ compatible TV (with DVB-S2 tuner). They only list ones on their site which will also automatically put the channels on their correct LCNs (e.g TF1 on 1, NRJ12 on 12 etc).
The one I have works fine in our Sony TV even though that's not listed by Fransat (you have to order the channels yourself).
