excollier
Bikes, Booze, Rock & Blues
- Mar 16, 2008
- TD 64 and Humax Foxsat HDR with Raydon's custom firmware
- County Donegal - furthest outpost of the EUSSR
Tricky question here.
I am using gear I bought new back in 1980. The amplifier is a Panasonic SU-2800.
My problem is noise on it's phono stage, like a buzzing along with a regular "ticking" sound.
I have an Aiwa turntable which also has a built in switchable phono stage, but it was switched off as the amp has it's own phono stage. This noise has been there ever since I replaced the original Panasonic turntable that died a few years ago. This noise is very noticeable and gets louder after an lp has been played.
Last weekend I bought a Rega Planar 1 turntable (I have been promising myself a quality turntable for ages). This also produces the noise but not as loud.
To try to run a check, I plugged the Aiwa tt into a spare line input and switched on it's phono stage - there is the noise again, via a different input ( all other inputs are normally noise free) so I'm guessing - no hoping - that this noise is down to a noisy mains supply and that phono stages are sensitive to it and pick it up. No other inputs or peripherals produce this noise.
One other thing, if I touch the pivot joint at the end of the tonearm on the Rega the noise gets louder until I remove my finger, even with the turntable powered off.
I have tried other power outlets too, but no difference, and the mains leads are away from any rca/phono leads.
Any thoughts and tips on this would be helpful.
With the turntable unplugged from the amp inputs the noise changes, more of a very quiet "white noise" than a buzzing, and no "ticking". Perhaps a grounding issue as both turntables have no ground wire, where the original Panasonic tt did have one and was noise free.
