MIS Transponders ETC
blademedia
Sky
Hello, new to using cards, while scanning I'm finding various transponders listed as multi input stream that I don't find listed on the usual sites,
Can we open these/how to find codes for new transponders ?.
I am not one for reporting my finds on the usual sites so I will post them here.
Archive-8
You can use crazy scan to find the pls codes.
pontiend
Contibruter
south yorkshire
They tend to be ACM coding blade.Normally Data transponders.Sometime they will Scan a channel in your viewer.with those results.
blademedia
Sky
They tend to be ACM coding blade.Normally Data transponders.Sometime they will Scan a channel in your viwer.with those results.I normally filter ACM coding out and only scan for CCM coding.
Thanks. yes I see them listed as data but there is type of video, reminds me of 4.2.2 another example here
blademedia
Sky
Found these charts the other day, gives me an idea of db needed to clear certain 16/32 apsk
What's required to get a stable image out of those acm streams?
MCelliotG
Thessaloniki, Greece
Hmmm, indeed the no lock indication sounds suspicious!
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
@Feedsat_DXer can you confirm where this ones from please, around 72.1E
Hi 'blademedia'........cannot see that far here but 12590 is shown by Flysat as being from 68.5ºE - Intelsat 20
blademedia
Sky
Enjoy the rest of your weekend. View attachment 100711
Thanks :)it must have been ghosting, I was E of 70E,
Another one I cant get to play, am I doing something wrong ?/don't these play ? this ones from 33E flysat has it listed as 16APSK I get it as 8psk
pontiend
Contibruter
south yorkshire
I get it at 8PSK too blade.
TBS6983 100cm Dish.
blademedia
Sky
Thanks, does it lock in as a channel for you that you cant watch ?
pontiend
Contibruter
south yorkshire
I did ask about this some time ago.Memory being what it is I have forgotten the answer.
Perhaps it has something to do with the stream type.This is continuos I think that normally they are transport.
blademedia
Sky
I did read a few post regarding continuous stream the posts was 2014, like 4.2.2 all over again :-doh
