Astra 1N @ 28E - about to go on air / on air!!
THORtenerife said:
TENERIFE 10.50 gmt SKY NEWS ITS BACK
whats happening (in english)
Did you have a small cloud covering your dish? ;)
Ratchet
Falkirk
TM 5402(M2), TBS 6983, Sky+ HD, Stab USALS HH100, Faval 1M, Triax TD54, Hauppauge HD PVR
Falkirk
Something going on with 12401 V and 12421 H, fluctuating signal and no lock. Swapping over to 1N in the middle of the day ???
Edit: Now locking again but lower power than before.
Edit #2: Power back to normal levels so probably not 1N yet.
welshman234
sky hd uk, 80cm kathrein dish,vu+ solo, humax f1 fox for hotbird 13
frankfurt
I think Sky news and Sky sports 2 are now broadcasting on Astra 1N as I said a transport stream of 07ea relates to a TID of 2026 this is Astra 1n according to KOS
welshman234
frankfurt
No wait transport stream on Sky news hd is 07d4 now changed again....
Dan Dan
19/26/28 1m
tenerife
Well as per my post i dont get 11.171 so the SKY NEWS that came back at 10.50 GMT is not on that can you recheck again and see what transport stream is now
(sky sports 2 is still there)
re welshman .sorry posted at same time...
welshman234
frankfurt
Thortenerife its 07d4 again therefore 2004 TID Astra 2a again...
Retired Mod
www.timo.me.uk
I'm not getting anything on 11.171H at the moment in the UK.
every day 12:00-1400 no signal all astra
i check tonight
Timo, where are you based? Helsinki or UK?
Ratchet
Falkirk
Falkirk
Ratchet said:
Power drop noticeable here also, just gone from 93% to 84% on my TM6800.
Now dropped even further to ~72% and fluctuating slightly.
Edit: Figures relate to 11165 H
Edit #2: Back up to 93% again
Dan Dan
19/26/28 1m
tenerife
i smell cock-ip,they switched off wrong SKY NEWS....someone said IRN use dedicated boxes for news here,and they would have to be retuned...plus cable feeds in ireland etc...its the last one that i would move. i have added 12207 in the ADD channels,so can double check if it happens again..
Retired Mod
www.timo.me.uk
I'm back in Buckinghamshire now. Had been rather hoping 1N would have been online properly before I came back...
welshman234
frankfurt
Something very odd has happened
Ratchet
Falkirk
Falkirk
11171 H is not active at the moment. There is a low S/R test 6Mhz away at 11165 H 1000 5/6
Retired Mod
www.timo.me.uk
The weird thing is I can't get that either on my TM6900.
11.127V is 90% quality and the other satellites are usually around 75-80%.
Dan Dan
19/26/28 1m
tenerife
12.401V NO SIGNAL -as per normal in TENERIFE
12.421H working OK - as per normal in TENERIFE
Dan Dan
19/26/28 1m
tenerife
Kof SAT say that some PID changes to Sky DIGITAL on EUROBIRD.you would have to do these ahead of changes to ASTRA ,as SES dont control it
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Here it's 07ea now
Ratchet
Falkirk
Falkirk
Not sure what happened there, the signal loss / fluctuation only lasted a couple of minutes. The signal levels returned to normal so no swap yet. These are prime candidates for going over to 1N so whatever went on was probably related to a potential move to 1N soon.
welshman234
frankfurt
Still o7d4 for me
