Astra 2E: Testing at 43.5E
BlindFaith
TBS 5925
Do not forget that Astra 2E is at 44.5 degrees now-20:42 local time and not 43.5E after N2YO
yes, it moved a little but IMHO less than 1.0 degree. I'd rather say 2E is now at 44.0E ;)
M60
Northern England
Tracking sites take time to update, can guarantee she'll be at 43.5E as proven by all the reception reports.
BlindFaith
TBS 5925
Well, I had to go 2 pulses eastwards to get to the maximum.
M60
Northern England
That's interesting, unless SES have decided to test her at at 44E? Guess there will be a TLE update Monday morning and we'll know a bit better exactly where she is.
I did also test with a 1.1 m dish and as you can see the signal can be received in this part of Europe.Surely 11710 H is on European spot;I think the rest are from the uk beam.
10958h
2db look low pe beam
Acuario
Tortosa, Catalunya
www.tortosaforum.com
1.2M Gibertini, 1.9 Famaval, 0.2dB Invacom LNB, Iris 9600HD, TBS5922
Southern Catalunya
Signal in Tortosa on a 1.9M dish is comparable with the signal on 2F so hopefully the footprint, as predicted, is the same.
You'll have to wait until it moves to 28E to do that comparison. Right now it is 15º further east.
M60
Northern England
gonzobaby
100cm Gibertini OP100XL
Inverto Black Ultra Quad
Vantage HD8000S
Technotrend S2-3600
Schoeningen, Germany
Here are my two reception reports from north-central Germany
djgeo_gr
Channel Master 3M motor 37,5W-57e
Dish Aris 2,4 motor 42e-30w
Dish Gibertiny OP1,25 motor 42e-30w
Dish Gibertiny OP1,25 9E, 13,16,19,2
Prof Revolution DVB-S2 8000 PCi
Technotrend S2-1600
Dreambox800seHDPVR
Dreambox7020si
Dreambox 500s
Azbox Elite
Greece - Crete Heraklion
good afternoon to all friend
south greece with Gibertiny OP125
djgeo_gr
Technotrend S2-1600
Dreambox800seHDPVR
Dreambox7020si
Dreambox 500s
Azbox Elite
here se second freq in H
11710
miha20
Kiev, Ukraine
I have no signal on 10818V in Kiev
Pietclock
125cm
SE Germany 50°N/11°E
so much testing on a Sunday... they are in a hurry, arent they...
I expect they don't want the original delays to cause the prospective Operational date to become entangled with Winterval.
10970v
1.5db
miha20
Kiev, Ukraine
no signal in Kiev on 110cm
2 likely reasons:
1) The clock is ticking - Sky's epg freeze kicks in mid December and at that point no channel changes / frequency changes are permitted. Even if a channel goes bust its not removed from the epg until early January.
2) If SES want / need 1N back at 19E for the xmas holiday they HAVE to have 2F on station at 28E & fully operational asap .
BlindFaith
TBS 5925
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
Might be 10967,V,30000 from Turksat
