Best receivers for weak transponders
newstar1974
Channel master 120+inverto black ultra
Sween
Tell me another receiver that will display dB signal level readings for those frequencies that are below a lock level, a very useful tool when hunting weak signals?
Add in to the requirements an easy to edit channel/satellte database and with user friendly menus - result, you are back at the fabled Dr HD F15.
Dr HD F15 is agreat receiver with great spectrum analyzer. for some reason for me with same dish and same lnb same tume could not lock weak signaled that locked by icone irone plus and vu+duo2
newstar1974
Sween
Thank you very much for great pic
The one i found on web shop is the top receiver , may be it is not possible to buy the botton any more . But if the performance of 1 st edition is simillar to Dr HD F15 then i already have dr hd f15.
TM5402 M3
Hmm, in a quick test of a Dr HD F15 and a TM-5402 (M3) side by side on the same frequency the F15 maintains a constant readout of the signal level even though it is below the level required for a lock.
The TM-5402 (M3) fails to maintain a constant readout and gives only a sporadic sub second flicker of nothing useful.
TM-5402 (M3) simply cannot compete against an F15.
Manikm909
Small'ish Dish Man
Kent, UK
thanks @moonbase - i wonder how a 5402 M1 would compare - same tuner i see? does it also have a spectrum an analyser like the F15 ? are they essentially the same...?
Manikm909
Small'ish Dish Man
Kent, UK
i might sell my 5302, 5402 M3 + M4, and 6902 - gathering dust and novelty has worn off.
newstar1974
Sween
Thanks for this useful test . I bought my dr hd f15 at sat shop in Finland for many years ago . Sometimes I wonder if mine is clone. Although I know that this sat shop has very good reputation.
Manikm909
Small'ish Dish Man
Kent, UK
i was thinking - ive been trying to get ESPN on 40.5w since ive made my KU ` CBAND adapter - the GT MEDIA COMBO shows 20% on the TP without lock but not ZERO....however I can get FS1 - 3 - very odd, as EPSN seemed stronger to me when the CBAND LNB was at central focus - so maybe theres a modern answer - whats your experience on PAKSAT with the combo?
jojoz
Emme Esse 115 Alu satellite dish
Stab HH120 diseqc motor
Golden Media High Gain Quad LNB 204+
Octagon SF8008 single satellie receiver
Athens Greece
And what about enigma receivers?
Which one has the best tuner sensitivity?
Has anybody done any comparison test?
jojoz
Athens Greece
Manikm909
Small'ish Dish Man
Kent, UK
enigma2 is useless in a "below lock" situation...
Manikm909
Small'ish Dish Man
Kent, UK
octagon SF8008
I liked my TM-5402 (M1) apart from the signal level readout in %. I think Technomate only made the option to use dB in the M3 model and possibly the M4 in the TM-5402 series?
I have the M3 'ere so can confirm it does dB but I never bought an M4, I swerved it.
Manikm909
Small'ish Dish Man
Kent, UK
nah M4 doesnt have DB - u did the right thing! useless.
i think the M3 - over states the DB reading.
I imported three Dr HD F15 units from probably the same shop in Finland.
The seller was genuine and used to import them from Russia, I think he is mentioned on this forum in one of the DR HD F15 topics?
Manikm909
Small'ish Dish Man
Kent, UK
im sure i will find it.... :)
Not dB level, but the GTCombo does a good impression in quality percentages. The fall off across the ranges is progressive despite being slated by 'those that know better', I find if the signal quality can be peaked to around 17% by tweaking what is outside - or inside by manipulation of the symbol rate - then there is a good chance I can lock signal and grab the streams.
For example a frequency on 36East, 11495V. Earlier it would not lock , but after nudging the dish and changing the symbol rate by 2MBps, in comes Al Mayadeen at 22%.
I would have to plug in the analyser to tell what 22% equates to in dB, but I know the Emitor has trouble locking onto a S2/8PSK signal (though it might give detail of the stream and how close it is to bagging the constellation).
newstar1974
Sween
My GTMedia Combo is bitched up bad, doorstop status. I gotta do the fix that is posted on the GTMedia forum but I have not got round to it yet.
I think i will go either for GTMEDIA GT COMBO or octagon SF8008. I will be very disappointed if tuner of receiver like icone irone plus perform better than all this receivers.
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Hi, i just did a test on 10.0E. Using dm900 & osmini4k receivers.
