Heavy duty polar mount prototype 1
Archived-1
Persona non grata
uk
15ft up in the air, i'm pleased your neighbours are okay with this. You'd never get away with that around here----lots of dogooders poking their nose just where it doesnt belong. You're going to get some serious windloading on that, thats going to test your welds Martin. Looks right smart so far though.:-applause
I have planning permission to put it there paul, but my neighbours are great people and we all help each other as it should be, mainly me helping them with been able to turn my hand to most things:-lol,
My welds will be fine there is enough room for error with the size of box section I am using;), thanks pal :)
How did you manage to get planning permission for it? Was it a pain?
wod
yorkshire
Your lucky to get planning permission, is the planning officer your next door neighbour lol
I guess you've camouflaged the dish face ?
People here aren't bothered about my dish in clear view been fine for years, thinking get the 1.2 out shed and up there.
Archived-1
Persona non grata
uk
It can be very easy to get permission if you have a suitable place for one like myself, i offered two plans one ground mounted central in the garden, and the 15ft pole option close to the wall, I wanted the second option and it all came off, i will post pictures of the first inspection when i install the pole.
Just taking a look at the weight 1.5 gib weighs 7.5Kg 1.8 CM 47.5kg, you might understand my concern a little more :eek:.
Spherical joints are brilliant. Reason you haven't seen them here is they are overkill on a satellite polar mount when you can get away with just a brass bush or no bearing at all. I used to use them on the end of the drive bars on a race car and never had a failure when pushing a 500kg car to 225Km/h in 9 seconds.
Archived-1
Persona non grata
uk
I managed a few hours today its only tacked in places but coming on fine and starting to look like a mount:).
Very nice. What do you cut the metal with? Don't say a hand hacksaw...
ched999uk
zone 1 sky type dish with quad lnb @28.2e, zone 2 sky dish with octo lnb @ 19.2e and Humax Foxsat HDR
Sunny Blackpool
Very nice. Think your photos will inspire others or at minimum get you a collection or adoring fans :-)
Need to invest in one of those methinks
ched999uk
Sunny Blackpool
Just remembered where I used to see Spherical joints. I used to test engine oils for MoD. We had engines mounted on a test bed with dynamometers to provide engine load. Long story but the load cells (device that measures how much load is applied to engine) were attached to frame by a spherical joint at each side. Basically a single spherical joint was able to take 750Nm (over 550ft lb) of torque and 230Kw of power!!!!!!
Can't find a good photo, it's a few years ago now. This one is from video. At the end of that drive bar is a quality 3/4" by 3/4" spherical joint.4097_0_0_0_0_0_0_0_0_0.jpg
Archived-1
Persona non grata
uk
If I was to use something like that I would use a track rod end, but all my plates are made now, all moving parts are accessible, so its not hard to replace any part if it wears but thanks lads,
I thought you wanted something strong. That's just a puny little steering joint.
So anyway what are you going to use for a bearing?
Piltdownpaul
No.1 Spike Milligan Fan
Piltdownpaul
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
You do indeed buddy ..
I use mine all the time for projects ..
..and my backyard is littered of steel bits n pieces..
lol
