Help!! S.o.s.
Veton Tigani said:
has anyone checked the pictures yet!? report plz, I posted the pictures so that It Is much easier for you to teach me & easier for me to understand :)
It would be much better if you could upload the photos to our server.
Veton Tigani
Kopernikus DCPI + S
Kosova
satelliteman said:
We advise waiting at least a day or two if not longer to get a reply. The majority of those that can help.. work so please wait for an answer :)
Uppss.. my fault, sorry If I sounded like I'm nagging, I didn't meant to :s
Veton Tigani
Kopernikus DCPI + S
Kosova
u mean upload them directly like adding pictures (upload) as comment!? yes I tried to do so first but It didn't work, that's why I uploaded them on a ImageSharing site & then put them here as links, btw... whats the difference I mean... as long as u can see them :s
Mickha
North West
I have now uploaded them for you, hopefully someone will help you out.
Veton Tigani
Kopernikus DCPI + S
Kosova
wooow THNX a lot :D
yep, hopefully someone could give me the instructions now based on the pictures. :)
Veton Tigani said:
... btw... whats the difference I mean... as long as u can see them
That's just it. When you upload to an outside site there's always a chance that the site might go down or, at some in the future, you delete the files yourself. Then, when someone else looks at this thread, all they see are red crosses instead of the photos.
Veton Tigani
Kopernikus DCPI + S
Kosova
guyz... I found It out how to search the channels & everything... & I was doing nothing wrong since from the beginning but the problem was somewhere else the satellite dish was hhmmm... the part which holds the dish was deformed & needed to be fine-tuned cause the dish kept pointing a bit down. now that It is fixed I just have to give in the correct frequencies & move the motorized dish a bit (& there where I get the highest signal... then I press search).
Ive tried to explain It as best as I could cause I'm not familiarized with these satellite terms, hope you are understanding me. :)
It sounds like it just needed a little bit of adjustment from what you're saying. Well done if you've managed to fix it.
