Masthead Amplifier problem
spike47
Sky dish on Freesat and Aerial on Freeview .both piped down to lounge TV and Bed 1 and a Sat cable to Bed 2 .
Skelton , Saltburn-by-the-Sea Yorkshire
Hi All
I have just fitted a Labgear 2 Way Masthead Amplifier PUL121 ( Picture Attached ) , to take a feed to a: Lounge TV , b: TV for Daughters Bedroom .
I have a 12 Volt feed from the Lounge TV up to the Masthead Amp , but I am not getting any signal to TV , I have checked the Continuity of the Cables and they check out OK , and I am getting 12 V at the Masthead .
Question , is there a way to test the PUL121 , is there any reading's I can check on it . I have only just bought it and I really wanted to know if there was a problem with the Unit before I try to take it back , if I can that it .
Note : I have taken a 1 way Masthead amp off that worked ok on my Lounge TV .
spike
A nonymous
Connect the feed with the power to the other output. On some mastheads powerpass is only allowed up one connection.
Try giving that a go. Failing that its probably a duff mast head amp. I have a tendency to shy away from Labgear stuff if i'm totally honest.
If you have no luck try something like a Vision V20-1220 mast head amplifier.
Nano
spike47
Hi Nano
Done what you suggested put power into other connector and it worked fine , I would not of thought to do that , mind you trust me to pick the wrong one .
cheers and thank you very much for your Help .
spike :-thumb1
Very bad of them not to put the right indication on the unit, unless there actually is a failure of the internal circuitry
spike47
You must be correct again , I keep getting a signal on the other output to my daughters room but it keeps going off , lounge TV ok , so it looks like it will have to come off and back to screwfix , 30 day warranty up yesterday , but will give it a try .
spike
aceb
Prof Tuner 7301 /
Sussex
As with all mastheads that quote upto 860MHz you might want to consider adding a new bandpass filter because with the imminent introduction of 4G (LTE) it might just save another trip up onto the roof.
spike
I'm still not certain it's the amplifier unit, the PSU would be providing 12v not only to the amplifier, but back down to the second TV if the circuitry is as per the sticker on the unit.
Can you scan the technical data that comes with the unit ? There might be something up with your daughters TV, shorting out the power supply, possibly the socket that is in the room
spike47
Hi Channel Hopper
I have just checked the voltage to my Daughters room and there is nothing showing ! , I am going to go back on the roof and check the voltage straight out of the amplifier that feeds my Daughters TV , will come back with the results .
thanks to ALL
spike
Just had a look at the tech spec of the amp on the labgear site, not very informative and from the lack of labelling would appear that both outputs should be capable of powering the amp. www.labgear.co.uk/category/amplifiers/masthead-amplifiers/2-way-uhf-mast-head-amplifier/1002/1013/45/#
Best idea is to take it back and either get a replacement, or fit a two way dc pass masthead splitter before your old known working masthead. You may even find that since switchover you just require a passive splitter, which would also be a future measure against possible 4G LTE interference.
spike47 said:
Hi Channel Hopper
thanks to ALL
spike
That may confirm there are two diodes within the unit, able to pass 12v up to the amplier, but preventing 12v from passing back down the second cable. One of those diodes may not be fully soldered on the board, giving you intermittent connection on one port
spike47
Hi All
Went on roof AGAIN , and took out the Amp to check it in doors , the weather is atrocious , looked at Connections and the middle one there is no spring clamp inside , well there is but it is wide open it will not have been clamping onto the central copper wire of the cable , I checked the voltage out of it with a wire waggling about inside and there is no voltage output at all , so it seems it has a production fault , with I must had , it has a "PASS" sticker on the back of it ! .
well guy's , thank you all for your help , of down to Screwfix in the morning to get a replacement , fingers crossed 30 day warranty out .
cheers
spike
A nonymous
I'd get your money back and buy a decent branded one from elsewhere if i'm totally honest.
nano
spike47
Hi
Just a update , I got a replacement unit and now up and running , just a couple of points on this crap Labgear shit , it says the voltage can be fitted to either outputs of the Amp , but that is not correct it will only work on the second output from the Aerial input .
And the other point is that there is not a 12 volt supply back down the other output as suggested ! , double checked with meter , no 12 volt ( there is some voltage showing on my Digital Test Meter but it is all over the place mainly in mV and that could just be some static etc from cable ) but TV working OK picking up on DTV over 160 channels . She is in heaven now .
Well guy's I can not thank you ALL enough for your time and help , the moral of the story is , " do not buy cheap shit" and expect the best .
spike
Does your replacement unit have the same issue of only one available injection point ?
spike47
Yes that is correct , only one that will take the uploaded voltage .
If it's mentioned in the accompanying instructions, then it is also faulty, unless there has been a design change (in which case it should have a different model number).
