NHK World HD transmission problems 28E
sonnetpete
wordpress.com
Normandy, France
It's showing the problem on my Vu+Solo at the moment......yet not on the Dr.HD
Yup, varies according to Rx.
Neither Skybox F3 shows the problem, nor does my non-PVR Humax Foxsat.
But the Humax Foxsat HDR does exhibit the effect.
Mystery.
They may be broadcasting more than one video standard down the one transport stream.
sonnetpete
wordpress.com
Normandy, France
For anyone who hasn't seen the problem, here's a screenshot I managed to grab....
And heres one I took a few seconds ago on the Duo
Theres a bloke standing on the right holding some white fabric. His left hand is front middle in amongst the blur
@ sonnetepete
Yup. That's it exactly. Slightly distracting, no more.
@ Analoguesat
Seems far worse on yours!
Its very patchy. the picture can be fine for quite a while then dissolve into that mush several times, or you can just get irregular breakup along the bottom.
And you just don't want irregular break up across the bottom :-toilet
sonnetpete
wordpress.com
Normandy, France
Hm, almost looks like a poor signal for sure. Maybe their feed/relay point is having issues and it's simply sent like that already? Does it happen on various receivers at the same time?
I'll see if I can compare signals over the weekend. I should be able to rig it so I can see the Sky box & the Duo at the same time.
The signal is weaker than the others - 62% on the Duo.Agauinst 90+% on the Astra 2 channels. The sooner Eute 28A is pensioned off & the frequencies moved over to the Astra 2's the better!
NHK HD no problem on my Dreambox 8000, but a check with Transedit analyser gives consistent pixellation, with a bitrate a steady 10Mbps. No problem with, e.g. BBC HD.
BlindFaith
TBS 5925
I can't see any missing packets. Preview with Transedit like other pc applications is based on Directshow. So it's not transedit but the filter that causes the artifacts. Simple solution: select a different decoder :D
Yes, silly me. changed to Cyberlink from default. Cheers.
davemurgtroyd
Oxford
Oxford
I am still seeing this on both NHK and RT HD on my Sky digibox DRX890 but not on a Libertview F5S on the same octo lnb on a zone 2 dish. Is anyone else also seeing this on RT HD?
Yes, RT is behaving the same as NHK ( ie dodgy on Humax Foxsat HDR, but not on Skybox F3. Dish independent).
Of all the dvb-s2 players(DVB Dream,DVBViewer)and tools, only with TransEdit Analyzer I have a slight pixellation on NHK HD,and not on RT HD.No problem on Dreambox HD.
Hmm interesting.
Set up:
Sky 2TB receiver
Vu+Duo shitebox
connected to the same lnb on the same dish
Watching in parallel on the main tv & the tv card in my computer for a few minutes.
Massive smearing on the Sky HD box. If anything its actually worse than it was a few days ago.
Less on the Duo, and its not happening at the same time.
