Reception of Badr4 (26E)
I have Saudi Sports on 12015 V 27500, loud and clear.
Badr-4 @ 26 east 12149 H 30000 Saudi Sports still no signal here on my 100cm has this transponder moved to Badr 5 or 6 ?
Badr 4 still, but has the worst dB value, and a tough FEC of 5/6.
Thanks for the replies I can get 12015 V but not the package on 12149 H 30000 ?
TM5502HD + 100cm Gibi with Inverto 0.2 Black Ultra
Signal Quality readings
11919 H 46%
11938 V 52%
11958 H 51%
11996 H 50%
12015 V 61%
12034 H 49%
12053 V 61%
12073 H 48%
12093 V 59%
12111 H 36%
12130 V 72%
12149 H 0%
12168 V 56%
12182 H 53%
12207 V 47%
12226 H 47%
12245 v 53%
12523 H 52%
12608 H 51%
12683 V 64%
12699 H 50%
12739 H 73%
http://www.lyngsat.com/Badr-4.html
pontiend
Contibruter
south yorkshire
l
DVDream gets nothing on 12149H .A blind scan gets it at 5.7dB.
Edit I should read posts properly.I get 12015V fine.:)
TBS 6925 100cm Dish
SatSearcher
West Yorkshire
Definitely something going on here, managed to get a lock on all BADR4 frequencies, but a couple are well down on normal figures, namely 12111H & 12149H, also had to mess with the USALS settings to get it peaked properly, don't normally have to! CrazyScan below:
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
Just an update on this. After a sobering chat with a local installer about how much it would cost to start from scratch, I sat down this evening and checked all satellite postitions again and, once again, more or less all were as they should be however I found out that nudging west made a big difference to some feeds on 10E so decided to repeat this on 26E and its back. The motor definitely does have a huge amount of backlash though - on the MBC transponders for instance, driving to it from the west results in 86% signal quality; driving from the east results in 56% quality! The motor's given me nearly 3 years faithful service to am wondering do I stick with it now and see if shifting positions fixes it or bite the bullet and go for a replacement motor and install - its far too high for me to deal with myself sadly :(
Retired human
I found the same thing with most motorised equipment. Everything from DiSEqC motors to Jaeger 1224 to jack arms. Not quite the massive margin you seem to have but a few SNR percentage points at least
Archived-1
Persona non grata
uk
Also don't forget even stable satellites do drift very slightly, to get the best from my setup i have to very slightly adjust every time the dish goes to a different position, try it you will be surprised what you can pick up.
Re-aligned dish declination & Lnb position
Signal Quality readings after adjustment this morning
11919 H 55%
11938 V 61%
11958 H 48%
11996 H 63%
12015 V 69%
12034 H 55%
12053 V 67%
12073 H 55%
12093 V 64%
12111 H 46%
12130 V 80%
12149 H 0% no signal
12168 V 68%
12182 H 53%
12207 V 58%
12226 H 52%
12245 V 62%
12523 H 55%
12608 H 51%
12634 H 34% AOL
12683 V 61%
12699 H 53%
12739 H 70%
Badr-4 @ 26 east signal quality monitoring
Time10:30am 4:30pm 9:30pm
11919 H 55%---57---
11938 V 61%---62
11958 H 48%---56
11996 H 63%---65
12015 V 69%---70
12034 H 55%---58
12053 V 67%---68
12073 H 55%---60
12093 V 64%---65
12111 H 46%---49
12130 V 80%---81
12149 H 0% ---45 signal returns
12168 V 68%---70
12182 H 53%---62
12207 V 58%---62
12226 H 52%---55
12245 V 62%---61
12523 H 55%---59
12608 H 51%---52
12634 H 34%---40 AOL
12683 V 61%---65
12699 H 53%---0 feed
12739 H 70%---70
21:30 hrs all transponders +2% change on previous readings from 16:30 hrs
22:30 GMT readings
11919 H 55%
11938 V 61%
11958 H 60%
11996 H 67%
12015 V 73%
12034 H 55%
12053 V 72%
12073 H 55%
12093 V 68%
12111 H 49%
12130 V 76%
12149 H 48%
12168 V 71%
12182 H 65%
12207 V 65%
12226 H 61%
12245 V 72%
12523 H 61%
12608 H 57%
12634 H 40% AOL
12683 V 68%
12699 H 67% feed
12739 H 87%
Signal Quality readings from Badr-4 @ 26 east with 100cm Gibi & 0.2 IBUltra
This morning's Signal Quality readings start 09:30hrs DTH Transponders only
----TM5502HD-----TM6902HD --AZBox-P+--SpiderboxHD9000
11919 H --53% ------57%--------44---------------44
11938 V-- 58%------62-----------50---------------46
11958 H --56%------58-----------47--------------46
11996 H --62%------60-----------54--------------54
12015 V --72%------67------------61--------------60
12034 H --53%-----58------------45--------------44
12053 V --72%-----66------------60---------------62
12073 H --53%-----58------------45---------------46
12093 V --66%-----63------------56---------------56
12111 H --48%-----54-------------41---------------40
12130 V --76%-----66-------------64--------------64
12149 H --46%-----51-------------40--------------40
12168 V --68%-----63-------------59--------------60
12182 H --62%-----61-------------54--------------54
12207 V --62-------60-------------53-------------54
12226 H --58%-----55-------------50-------------50
12245 V --68%-----60-------------57-------------58
12523 H --57%-----56-------------50-------------50
12683 V --64%-----61-------------54-------------54
Test ended 10:40am
The AZBox & Spiderbox give a more accurate signal readings when compared to the false elevated readings from the TM's.
Tururu
Assembled with recycled parts
Recycled as the owner.
To the south, very good sign.
Madrid (Spain) 94cm antenna, DreamBox800S-HD.
11919 H  13'5db señal/SNR  87% Calidad/AGC 99% BER 0
11938 V  13'0db señal/SNR  81% Calidad/AGC 99% BER 0
11958 H  13'0db señal/SNR  81% Calidad/AGC 99% BER 0
11996 H  13'5db señal/SNR  84% Calidad/AGC 99% BER 0
12015 V  14'5db señal/SNR  90% Calidad/AGC 99% BER 0
12034 H  13'5db señal/SNR  87% Calidad/AGC 99% BER 0
12053 V  14'5db señal/SNR  90% Calidad/AGC 99% BER 0
12073 H  13'5db señal/SNR  84% Calidad/AGC 99% BER 0
12093 V  13'5db señal/SNR  84% Calidad/AGC 99% BER 0
12111 H  12'5db señal/SNR  78% Calidad/AGC 99% BER 0
12130 V  14'0db señal/SNR  87% Calidad/AGC 99% BER 0
12149 H  11'5db señal/SNR  71% Calidad/AGC 99% BER 0
12168 V  14'5db señal/SNR  90% Calidad/AGC 99% BER 0
12182 H  14'5db señal/SNR  90% Calidad/AGC 99% BER 0
12207 V  13'5db señal/SNR  84% Calidad/AGC 99% BER 0
12226 H  13'5db señal/SNR  84% Calidad/AGC 99% BER 0
12245 V  14'0db señal/SNR  87% Calidad/AGC 99% BER 0
12523 H  12'0db señal/SNR  75% Calidad/AGC 99% BER 0
12683 V  12'5db señal/SNR  78% Calidad/AGC 99% BER 0
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I just scanned this satellite. CM120 (partially obstructed by balcony's rail), IBU, GB Quad Plus, Brussels.ScreenHunter_225 Mar. 13 18.40.jpg
Tururu
Thanks for the info.
Clear now maintain levels.
12740 H 2200 very unstable, jump 50dB to 46dB all the time.
Madrid (Spain) 94cm antenna.
SR bass note and the antenna is small.
The FSS beam is very real
(Madrid-Spain) 48dBW ==> 60cm.
Also with IBU.:)
Gracias por la informacion.
Nublado ahora, mantengo niveles.
12740 H 2200 muy inestable, salta de 50dB a 46dB todo el rato.
Madrid (España), con antena de 94cm.
Se nota el SR bajo y la antena es pequeña.
El haz FSS es muy real
(Madrid-España) 48dBW ==> 60cm.
Tambien con IBU.:)
11919H27500  14'0dB señal/SNR  87% Calidad/AGC 99% BER 0
11938V27500  13'5dB señal/SNR  84% Calidad/AGC 99% BER 0
11958H27500  13'5dB señal/SNR  84% Calidad/AGC 99% BER 0
11996H27500  13'5dB señal/SNR  84% Calidad/AGC 99% BER 0
12015V27500  14'5dB señal/SNR  90% Calidad/AGC 99% BER 0
12034H27500  13'5dB señal/SNR  87% Calidad/AGC 99% BER 0
12053V27500  14'5dB señal/SNR  90% Calidad/AGC 99% BER 0
12073H27500  14'0dB señal/SNR  87% Calidad/AGC 99% BER 0
12093V27500  13'5dB señal/SNR  84% Calidad/AGC 99% BER 0
12111H27500  13'0dB señal/SNR  81% Calidad/AGC 99% BER 0
12130V27500  15'0dB señal/SNR  93% Calidad/AGC 99% BER 0
12149H30000  12'0dB señal/SNR  75% Calidad/AGC 99% BER 0
12168V22000  15'0dB señal/SNR  93% Calidad/AGC 99% BER 0
12182H16200  15'0dB señal/SNR  93% Calidad/AGC 99% BER 0
12207V27500  14'0dB señal/SNR  87% Calidad/AGC 99% BER 0
12226H27500  13'5dB señal/SNR  84% Calidad/AGC 99% BER 0
12245V27500  14'0dB señal/SNR  87% Calidad/AGC 99% BER 0
12523H27500  12'0dB señal/SNR  75% Calidad/AGC 99% BER 0
12608H 3000  10'0dB señal/SNR  62% Calidad/AGC 93% BER 0
12615V 2960  7'5dB señal/SNR  46% Calidad/AGC 89% BER26
12666H 2400  6'5dB señal/SNR  43% Calidad/AGC 89% BER147
12683V27500  13'0dB señal/SNR  81% Calidad/AGC 99% BER 0
12740H 2200  7'5dB señal/SNR  46% Calidad/AGC 89% BER141
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Alicante, España....1.2m
26.0ºE  13-03-2015  a.JPG 26.0ºE  13-03-2015  b.JPG 26.0ºE  13-03-2015  c.JPG 26.0ºE  13-03-2015  d.JPG
100cm Gibi with TM5402HD M3 + Inverto 0.2 Black Ultra
Signal Quality Readings received from transponders on Badr-4 @ 26 east
11919 H 27500 7.4dB
11938 V 27500 8.4dB
11958 H 27500 8.1dB
11996 H 27500 9.1dB
12015 V 27500 9.4dB
12034 H 27500 7.5dB
12053 V 27500 9.6dB
12073 H 27500 7.5dB
12093 V 27500 9.1dB
12111 H 27500 6.5dB
12130 V 27500 10.2dB
12149 H 30000 6.5dB
12168 V 22000 8.5dB
12182 H 16200 8.3dB
12207 V 27500 8.4dB
12226 H 27500 8.1dB
12245 V 27500 8.7dB
12523 H 27500 8.3dB
12608 H 3000 7.2dB
12614 V 2960 4.9dB
12666 H 2400 5.3dB
12683 V 27500 8.7dB
12699 H 2532 7.3dB
12739 H 2200 9.0dB
164 x tv 73 x radio
digi247
NW
see sig
I checked those readings on my M3 yesterday and all average between 11db and 12.5db obviously using a larger dish with a Twin Black Ultra
Using Patch 117p on the M3 as this appears to give a more accurate reading than any others
RimaNTSS
N-E from Riga
all average between 11db and 12.5db obviously using a larger dish.... i also get some frequency's which are out of your reach which average around 5-7db
Of course, bigger dish-better reception. Could you publish list of frequencies and levels you got? And lager dish you use means...?:rolleyes:
