Reception of Badr4 (26E)
blademedia
Sky
My signal at12149 this afternoon signal gets stronger at night at my location 1.2 channel master dish.
I beleive the signal comes from Astra 2E @ 28.5 east
06.09.2016 11428 H
DVB-S/MPEG-2 27500 2/3 Freesat w 2E
TRP 1
encrypted
TRP 1 6001 6002 Eng 10600
Conax
-R- Freesat Info
3603 Eng 10530
© w
FlySat Astra 2E/2F/2G @ 28.2° East
blademedia
Sky
06.09.2016 11428 H
TRP 1
encrypted
Conax
-R- Freesat Info
3603 Eng 10530
© w
Yes William thanks again you did post the info in post 71, 11428 is very strong for me for some reason I don't loose it until I get to very near to 23.5 I have had problems with ghosting around 28 in the past.
blademedia
Sky
11938/27500/V 9.8/10db, new UHD channel here.
MCelliotG
Thessaloniki, Greece
According to Flysat there is a new T2-MI mux for MBC HD on 12600V 25000 8PSK 2/3 on Badr 4.
On my system I have no signal, although I have to say that my motor needs readjustment, I'm way off on the eastern side!
Has anyone succeeded to lock the frequency?
Archive4
Only have the Extrend 9500 to check with, but I cannot see anything on there
MCelliotG
The transmission is said to be standard DVB-S2 so it can be received with any HD receiver despite the fact that it won't download any channels!
Nothing here.
This transmission in T2-M1 requires a compatible receiver to resolve this transmission,
None of my satellite receivers can download this transponder I will check with the spectrum analyzer later to confirm if this is a beam we can receive,
12600 V
DVB-S2/8PSK
MPEG-4
T2-MI 25000 2/3
Yes I can confirm it is active but very weak here.
MCelliotG
If Flysat's data is correct, it should work just like the T2-MI streams on 55E, meaning it can be locked but no channels on standard receivers. Unless it is also a MIS with PLS scrambling like Zeonbud on 4.8E!
MCelliotG
I suspect that as well, perhaps a PLS too!
However if the T2-MI contains the channels Flysat lists, I don't think SR 4000 could be enough!
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
From Cyprus with 2.1m . Its PL Scrambling.
MCelliotG
I have now just scanned with EBS pro and I get a no-lock signal at 8.5db. I will search for the code and hopefully we'll get this!
Lexzie
TBS 5925 USB-tuner
The Netherlands
I can receive 11958H, 11996H, 12015V, 12054V, 12207V, 12226H, 12245V, 12523V and 12683V
but not:
11919H, 11938V, 11977V, 12034H, 12073H, 12111H-12182H and 12740H
Anyone know why I cannot receive those when in the past I used to get the most of them (especially I'm sure of receiving MBC quite good) since the most of them have the same parameters as the one I can receive?
Are they still on Badr 4?
Archive4
According to most sites they are all on the same bird , so should not be a problem , however , there is talk of a new bird taking over , so maybe it has started.
Cannot check now as it is Emmerdale time and if I did , I´d be making no further posts!
Its quite possible they have moved to Badr-7
FORKS
1.5M Gibby Dish 62E-40.5W ,75cm for 52.5 Turkman SAT,
+ Long 60M CT125 cable run , TBS 6983 , TBS 6922.
West London 51.45 N
but not:
See attach my H Scan from 19.07pm UK time.
Hope this helps
