UPDATED April 12th 2010 :- Sly UK Bouquets
totalacedude
Edit. 5620 several 500,'s (clones) vu duo blackhole pc server 95cms motorised dish blah blahh
crewe
oh yea.
sorry meant to say there is no channel 373 i just put mtv trax there to see if i could.. and obv i couldnt lolol
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
You can add any channel anywhere in the First bouquet, but make sure you remove the corresponding 'Place Holder Channel' to ensure that subsequent channel numbering remains correct.
totalacedude
crewe
yea did that... but could access it from bouquets, but if i type 373 it takes me to the place holder channel still... lol
cheers ian :)
B16MCC
/var/tuxbox/config
You need to put the channel in the Frist Bouquet (SKY UK® 28.2°e by B16MCC©), in place of the 373 Place Holder Channel. It's no good just putting it in the Music Bouquet, you must put it in both. The first bouquet is the one that takes care of the channel number assignment.
ireilly24
DM800HD
FULL SKY UK HD
leicester
hi b16mcc i have done a rescan tonight as i noticed a few channels going missing and i have got a lot of channels not in the bouquets now do you have an updated version?
cheers ian
B16MCC
/var/tuxbox/config
HI mate, could you list them please ? The latest release is a scan from 5th april, it should be spot on with the recent changes. Also, when you scan, what is the total number of services found ? I'm currently showing 1182.
ireilly24
DM800HD
FULL SKY UK HD
leicester
its around that number of channels found. could it be to do with needing to take the bouquets off before the scann?
it has listed around 20 various missing channels and sky active have all gone!
thinking aloud would it be best to take my inline amp out of the loop before scann?
B16MCC
/var/tuxbox/config
Hi mate, I will endeavor to resolve the differences we have found however you must appreciate we are dealing with an exact art here. In order to sort this out I need to know ...
1. exactly how many services you get when you scan.
2. When you say 'missing' , what do you mean, missing from where ?
3. What channels do you have that I don't ?
With regard to question 3, my latest listing was put together using the Sly online EPG as a reference, and so if you disregard the Sly Box Office bouquet this listing is about 98% accurate, could you give me as much detail as possible please?
Cheers...
ireilly24
DM800HD
FULL SKY UK HD
leicester
i am on it now bear with me
ireilly24
DM800HD
FULL SKY UK HD
leicester
1143 services found, i am going to reinstall the bouquets now to see if any channels are missing.
ireilly24
DM800HD
FULL SKY UK HD
leicester
ok put the bouquets and everything looks perfect again must of been a confliction on the rescan somewhere :)
i originaly did the rescan as espn hd was saying service not found pid at pat or something like that, unfortunately this is now the case again do you have any ideas on that one please? :(
cheers ian
B16MCC
/var/tuxbox/config
Right mate, firstly, my scan shows 1182 services, so it seems you may have a few missing transponders perhaps.
As for ESPN HD it seems it may have moved. It shows several times in the 'Satellites' list and 2 of them give the Sid not found in pat message.
It seems the one on 12.342V 29500 3/4 with a SID of 3842 is the one that works.
I'll make this change for the next release of my bouquets. Thanks for pointing it out. Making a bouquet listing like this unfortunately will often suffer from issues like this , as channels get moved and changed all the time.
ireilly24
DM800HD
FULL SKY UK HD
leicester
ok great i couldnt get 1 of them to work but i look forward to your next release!:)
cheers ian
oldfart
laminas 2.7 offset
Invacom Quattro LNB
Chayofa, Tenerife
DM8K
Tenerife
Fancy adding the BBCi channels (red button on a sly box - I seem to recall)
B16MCC
/var/tuxbox/config
All 7 BBCi channels are already in the bouquet list.
oldfart
laminas 2.7 offset
Invacom Quattro LNB
Chayofa, Tenerife
DM8K
Tenerife
oops .. missed that one!!!
B16MCC
/var/tuxbox/config
Changes :-
Fixed ESPN HD
Changed names of Sly Movies Screen 1 & 2
Changed names of Zone Movie channels
Added missing channel, BabyFirst
Started adding numbering to every channel so they appear in order in the main display pane. ( Not yet complete ).
Changed the panic button channel to a different BBC1 to avoid zapping problems.
Bouquets updated :-
Main bouquet
HD channels
Movies
Sports
Kids
ireilly24
DM800HD
FULL SKY UK HD
leicester
just put them on and they look great top job again!!!! many thanks
oldfart
laminas 2.7 offset
Invacom Quattro LNB
Chayofa, Tenerife
DM8K
Tenerife
Wierd ..
if you upload using Dreamedit - the list has both sets of numbers (channel no. & the bouqet number)
If you upload using dreamset, you don't get the bouquet number
Huh??
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD Qaud 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
Great job with these, prob the best available for sky uk :)
