UPDATED April 12th 2010 :- Sly UK Bouquets
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
That is odd for sure. Try a factory reset and then add the entire bouquet from DBEdit without scanning the satellite.
gsmtechuk
Dreambox 500S
Standard Minidish
Tried adding the bouquets after a factory reset, without a transponder scan same issue.
- But without a transponder scan the affected channels also sont exist in the all services list.
- they give blank screens.
- After a transponder scan, I can find the affected channels in the all services list, however they are on different frequencies to those in the bouquets.
B16MCC
/var/tuxbox/config
Could you list the channels please ?
gsmtechuk
Dreambox 500S
Standard Minidish
I will have a look for a complete list tonight i'll see if I can find out what frequency they succesfully clear on as well from the all services list, but 3 that are definitely affected are:
Star One
833-Brit Asia
840-Sikh Channel
gsmtechuk
Dreambox 500S
Standard Minidish
Infact, ignore me...I was using an older set of bouquets from earlier in the thread..just tried your latest set 27th March...after a Factory reset and without scanning transponders and the problem seems to have gone !
All channels seem OK. I'm still testing but looks good so far.
Great work on the bouquets by the way, cheers
ireilly24
DM800HD
FULL SKY UK HD
leicester
hi bm16cc can you advise me how to get sky box office in my bouquets please. my provider is showing the fight but i dont know how to get it?
any help would be greatly appreciated
B16MCC
/var/tuxbox/config
Its one of the Sly Box Office data channels, but I have no idea which one. You'll have to change the type to 1 for TV instead of data. Also you'll have to buy it ofcourse, you're card won't just open the channel.
FoxForceFive
DM800s
Liverpool
How do you mean change type to 1 for tv instead of data? In DBEdit or on the box itself? Ta.
EDIT:
I've put the latest version of your bouquet into DBedit & if I'm reading correctly the type is already set to TV for all the Box office channels.
Also, as there's only one HD channel, if you order it on Box Office HD1 surely that's gotta be right?
ireilly24
DM800HD
FULL SKY UK HD
leicester
i was told to edit some settings on sbo hd1 and then add it to my bouquets will this work aswell
SGTFlipFlop
Dreambox 500-s x4
Scotland
B16MCC you seem to be missing E4 HD came out a few months ago buddy.
Keep up the good work
B16MCC
/var/tuxbox/config
It's in there mate. Just checked the v2.2 release, its defo there, Channel 215 in the main bouquet and in the HD bouquet.
FoxForceFive
DM800s
Liverpool
what settings?
Hatchet
DM800
Glasgow
I can't find the frequency for SBO either.
Sd or HD, and i have bought the fight.
B16MCC
/var/tuxbox/config
I think one of them is channel 743, which I think is the one I've found here. From a scan it doesn't even have a name in the list and its set as Data type. So I've edited it and added it to the bouquet as shown in the attached pic. Can someone who bought the fight please test it whilst you have access to the re-runs today.
FoxForceFive
DM800s
Liverpool
I got it working with the following settings.
I've been told on HD boxes can get Box Office events. Basically find your Sky Box Office HD1 in DBedit & make the settings match what they do in this image:
B16MCC
/var/tuxbox/config
Removed Men & Motors from Channel 178
Added the official ITV 1 HD on Channel 178. (No more need for manual lamedb editing)
Added Sly 3D on Channel 217
Fixed a copy & paste cock up, where I had duplicate channels in the movies section.
ITV1 HD is now listed 4 times, I don't know why, wether it's regional or what. 1 of them is probably for c a b l e tv. Anyway I've used the one that shows a full EPG when using Satmates Sly UK premade EPG dat file.
Bouquets updated :-
Main Channel numbering bouquet
Entertainment
HD Channels
ireilly24
DM800HD
FULL SKY UK HD
leicester
thats awsome thanks, do you have any idea to get the sly box office channels as i realy wanted to watch the boxing the other night but couldnt?
satelliteman
Thanks B16MCC, nicely laid out :)
ireilly24
DM800HD
FULL SKY UK HD
leicester
hi b16mcc thanks very much for the bouquets, since adding it to my 800hd clone when i out on espn i get service not working "sid not found at pat"! the channel was very glitchy prior to me adding the bouquet so it could be that?
totalacedude
Edit. 5620 several 500,'s (clones) vu duo blackhole pc server 95cms motorised dish blah blahh
crewe
hi, just something for b16mcc to peek at! (or any 1 else thats interested)
just sorted audio channels on some music channels, now there is audio. ie channels 351-358
removed panic channel as on 500's this causes problems ie type 101 u go to 1, then press up and u dont go to channel 102 u go to 2 (place holder channel) now if u press 101, 102 is next.
have tried adding 373 to the list, but u can only get to it via bouquet
(this is the 1st time ever i have played with dbedit)
?? how do i add this to the main listing ?? b16mcc ???
only added this as bonus channel to music cos i wanted to play and c if i could
obv i cant lol.
like i say its my 1st go and i dont understand it yet...
cheers ian
