Musaic MPL Music Player
Archive-8
@Channel Hopper do you know if these?
£249.95
The Musaic MPL can connect to anything with an analog ‘line-level’ input (such as a ‘CD’ or ‘Aux’ input). It can also connect digitally to anything with an S/PDIF or TOSlink (optical) input. The analog output features a very high quality ESS SABRE™ DAC. The MPL also features IR learning with IR blaster output and an emitter out for volume and mute commands.
Compatible with:
  • Wi-Fi and Ethernet
  • Apple and Android phones and tablets
  • The leading streaming services including TIDAL and Napster
  • Spotify Connect™
  • HTC Connect™
  • More than 30,000 internet radio stations and podcasts
  • NAS drives and UPnP/DLNA servers
  • Almost any file type including 24-bit Studio Master files
  • Philips Hue lighting systems
  • Smart home products from hundreds of brands via IFTTT
Tech Spec
ETHERNET:
100 Base-T
WI-FI:
802.11 b/g/n (dual band)
DAC:
ESS ES9010K2M 32Bit SABRE™ DAC with time domain jitter elimination
ANALOG FILTER:
Balanced 2nd order linear phase Bessel
SPECIFICATIONS:
Output voltage: 1.95Vrms max (0dB FS)
Frequency response: 0dB at 20Hz, -0.3dB @ 20kHz/40kHz/80kHz (depending on sample rate)
THD: <0.006% 20kHz-20kHz
SNR: >98dB
Bit depth supported: 16-24 Bit
Sample rate supported: 32-192kHz
Analog input: 24 bit A/D
IR Learning: 36-40kHz modulation
REAR CONNECTIONS:
PSU: 1 x 7V DC PSU input (adaptor supplied)
Reset: 1 x reset button
WPS: 1 x Wi-Fi Protected Setup button
Ethernet: 1 x RJ45
IR Out: 1 x 3.5mm mini jack for IR Emitter
Digital Outputs: 1 x TOSlink Optical, 1 x S/PDIF Co-axial
Analog Outputs: 1 x RCA/Phono Left/Right pair
Aux Input: 1 x 3.5mm stereo mini-jack
FILE FORMAT COMPATIBILITY:
MP3: CBR and VBR, 32kbps to 320kbps, 16 Bit 32-48kHz
AAC: CBR and VBR, 32kbps to 320kbps, 16 Bit 32-48kHz
AAC LC, HE AAC (AAC+) and HE AAC V2
FLAC: 16 and 24 Bit, 32kHz to 192kHz
Apple Lossless (ALAC): 16 and 24 Bit, 32kHz to 192kHz
AIFF: 16 and 24 Bit, 32kHz to 192kHz
WAV: 16 and 24 Bit, 32kHz to 192kHz
Just one of thousands reliant on crowdfunding and favours to get on the map.
Be very wary of parting with your cash, especially with the registered office remaining as the formation company.
https://www.madesimplegroup.com/
As for the 'first' smart hiring, they could be taken to task on that.
Which of the hardware features are their unique selling point to you ?
Archive-8
Was just looking around.
And I really wanted a high resolution play back, the sabre dacs also made me look.
And I was trying to find out more information on internet radio.
As I want my coco radio back :D its been a long time.
I need the dac to also have optical output.
There was a Cabasse unit in the pipeline, I'd have to check on progress.
So the home automation connectivity isn't of importance then.
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
Ive been looking at music systems on and off for the last few months.... I was having a few parties at the house over Christmas
and wanted something for music playlists etc.
Because I have a prime video account with Amazon I get Amazon music too.... a kind of Spotify service which is not brilliant but ok
Although they apparently advertise 40million songs they still don't have a lot of my favourite music :/
but for the full experience like Spotify its £10 a month.... maybe you get access to more songs then?
I have a fairly decent Bluetooth speaker set in the dining room and can stream either service from my Phone, PC or Amazon Firestick via TVs Bluetooth.
The problem is I wanted to play to more speakers and Bluetooth will only allow 1 connection.
Interestingly if you have a paid for Spotify account you can make use of another app called "Jukestar" which means guests at your party use smartphones to add songs
or they can down-vote a song and get it removed off the playlist.... even the current song that's playing. It has an intelligent system too so if one friend tried
to hog the playlist be adding 20 songs it will add them randomly into the playlist behind other friends music.
People can also look through the playlist and up-vote songs so they get played quicker too.
Ideally for me would be wireless speakers around the house that used the wifi to connect to a NAS with a music library or couldn't also use these Spotify/Amazon/Google playlists
Ive yet to see what I'm wanting.
Archive-8
I can only find the earlier spec sheet, but it does include the Stream Source
http://www.cabasse.com/documents/catalogue_stream_us.pdf
And an old review
Cabasse Stream Source: An Island In The Stream - The Audiophile Man
Thanks from a quick look, I like what I am reading, will look more into it.
I have a Spotify account, on a 3 months for 0.99p Sound quality is ok.
Had a tidal sub and wasn't impressed with the collection of artists.
I use a FreeNAS for my digital music storage, there's a few hundred gigs of it, then there's the record collection, I have lost count, I have a back wall covered in them.
And there's my aging old tape collection, and my sacd collection, a small shm collection and finally a very large cd collection.
My maverick d1+ tube magic has my kodi/pc input, that's been tube rolled to a GE tube and I have upgraded the dac chips to the burr-brown chips :-)
