Archive-8
@Channel Hopper do you know if these?
Musaic MPL Music Player
£249.95
![IMG_0207.JPG IMG_0207.JPG](https://www.satellites.co.uk/data/attachments/88/88855-4bb91c854d9420330858a92cd1ce827a.jpg)
The Musaic MPL can connect to anything with an analog ‘line-level’ input (such as a ‘CD’ or ‘Aux’ input). It can also connect digitally to anything with an S/PDIF or TOSlink (optical) input. The analog output features a very high quality ESS SABRE™ DAC. The MPL also features IR learning with IR blaster output and an emitter out for volume and mute commands.
Compatible with:
ETHERNET:
100 Base-T
WI-FI:
802.11 b/g/n (dual band)
DAC:
ESS ES9010K2M 32Bit SABRE™ DAC with time domain jitter elimination
ANALOG FILTER:
Balanced 2nd order linear phase Bessel
SPECIFICATIONS:
Output voltage: 1.95Vrms max (0dB FS)
Frequency response: 0dB at 20Hz, -0.3dB @ 20kHz/40kHz/80kHz (depending on sample rate)
THD: <0.006% 20kHz-20kHz
SNR: >98dB
Bit depth supported: 16-24 Bit
Sample rate supported: 32-192kHz
Analog input: 24 bit A/D
IR Learning: 36-40kHz modulation
REAR CONNECTIONS:
PSU: 1 x 7V DC PSU input (adaptor supplied)
Reset: 1 x reset button
WPS: 1 x Wi-Fi Protected Setup button
Ethernet: 1 x RJ45
IR Out: 1 x 3.5mm mini jack for IR Emitter
Digital Outputs: 1 x TOSlink Optical, 1 x S/PDIF Co-axial
Analog Outputs: 1 x RCA/Phono Left/Right pair
Aux Input: 1 x 3.5mm stereo mini-jack
FILE FORMAT COMPATIBILITY:
MP3: CBR and VBR, 32kbps to 320kbps, 16 Bit 32-48kHz
AAC: CBR and VBR, 32kbps to 320kbps, 16 Bit 32-48kHz
AAC LC, HE AAC (AAC+) and HE AAC V2
FLAC: 16 and 24 Bit, 32kHz to 192kHz
Apple Lossless (ALAC): 16 and 24 Bit, 32kHz to 192kHz
AIFF: 16 and 24 Bit, 32kHz to 192kHz
WAV: 16 and 24 Bit, 32kHz to 192kHz
£249.95
Compatible with:
- Wi-Fi and Ethernet
- Apple and Android phones and tablets
- The leading streaming services including TIDAL and Napster
- Spotify Connect™
- HTC Connect™
- More than 30,000 internet radio stations and podcasts
- NAS drives and UPnP/DLNA servers
- Almost any file type including 24-bit Studio Master files
- Philips Hue lighting systems
- Smart home products from hundreds of brands via IFTTT
ETHERNET:
100 Base-T
WI-FI:
DAC:
ANALOG FILTER:
SPECIFICATIONS:
SNR: >98dB
REAR CONNECTIONS:
Ethernet: 1 x RJ45
