Can someone help with some TP's on sats after 53e (South UK)
Manikm909
Small'ish Dish Man
Kent, UK
hey guys
im currently getting about 15db on various TPs on 53e - i suspect i might be able to get some more east sats \ tps - based on that strength - i could be wrong.
however, im not sure what else i can get after 53e, and i need some strong known TPs on various EAST sats after 53e which are known working so i can tune in, then nudge dish to see if the signal comes in.
many thanks
On 54.9°E 12522 V 27500 & 12531 H 2500 are reasonably strong.
Manikm909
Small'ish Dish Man
Kent, UK
Thanks . What are the full TP details fec etc . Thanks
Here is a list of transponders at 53.0E,which I have scanned now.It may help.
Manikm909
Small'ish Dish Man
Kent, UK
ok, so let me check something - regarding the 2 degree difference
my vbox counter for 4..8e is 985 and 7.0e is 975 - so thats 5 clicks per degree roughly
when i try 9 or 10 clicks east after 53e (for 54.9) all it found is this data stream....
11042 H
DVB-S2/16APSK
ACM​
4544 2/3​
That's 54.9°E, did you try to maximise the signal on that TP and scan again?
Manikm909
Small'ish Dish Man
Kent, UK
Yeah but why is it finding the data stream but not the others . I'll try on octagon . The icecryot is finding that data stream
Manikm909
Small'ish Dish Man
Kent, UK
Perhaps that's the strongest signal, and either the line of sight is partially blocked or the dish isn't perfectly aligned.
Manikm909
Small'ish Dish Man
Kent, UK
thanks, yeah, i doubt its alignment on the basis of strengths at 30w 16.5db and 53e 14db - more likely blocked my neighbours trees
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
12531 is more stronger in Midlothian @ xcruiser 785 @ 1 meter Gibertini @ IBU
11042 H
DVB-S2/16APSK
ACM​
4544 2/3​
What motor do you have? If it's a polar mount, clicks are not uniform across the arc.
Manikm909
Small'ish Dish Man
Kent, UK
SMR 128g. I'm giving up. I must be on it to get the data feeds just not the channels . Must be a blockage with line of sight
Ah OK - the SMR will be linear.
I have good signal on 53E but 55E is significantly lower than it should be due to neighbour's trees. The relative gap between two positions at extremes of the arc is larger than at the centre.
...The relative gap between two positions at extremes of the arc is larger than at the centre.
Surely the opposite of that as sats at the ends of the arc are further away from the receiving dish than when they are the southern-most sats for that dish location??
Manikm909
Small'ish Dish Man
Kent, UK
thanks to everyone for their input on this
Manikm909
Small'ish Dish Man
Kent, UK
after 54.9 anything else available...in case the further i go, it might not be as obstructed...
