s-band
- Feb 7, 2016
- Essex
The original thread is closed but here is the answer to:
The picture shows the mount on a Prodelin Ka band dish. The axes of the servo motor and the feed are aligned, hence the adjustments. These are the parts used:
I used a Polulu USB to pulse module to control the servo but you could use one of these:
servo tester | eBay but make sure it has a wide range.
The brackets, on the servo, either come with it or can be bought separately. Search: servo bracket robotics
Low Elevation Angle (1 degree -5 degree) Satellite Reception
Satellite signals at low elevation angle (1 deg- 5deg.) to a particular location is affected by many atmosphere related things like atmospheric scintillation, faraday rotation etc. which cause fluctuation in signal quality severely at reception end. While watching few videos on Youtube I...
www.satellites.co.uk
Plumbing Supplies | Plumbing Materials | Plumbing Superstore®
Plumbing Superstore is one of the UK's leading online plumbing suppliers, offering John Guest Speedfit, Armacell, Pegler Yorkshire and more.
www.jtmplumbing.co.uk
