U bolt for 3 inch pole
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
Does anyone know where I would get u bolts for t&k brackets that allow a 3 inch pole.
The t&k brackets i have, there are u bolts that allow a 2 inch pole, the holes on the brackets are wide enough to fit a 3 inch pole, need it for a 1.2 channel master.
Pop into any Exhaust Centre and ask if you can rummage through their fitments bins.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
And, BTW, it is not so difficult to make any U-bolt yourself, just take threaded bar and properly bend it ( I've done it couple of times).
jpsr
Mullingar, Ireland
Good idea, I'll get threaded bar, thanks.
RimaNTSS
N-E from Riga
Just one advice- take long bar, will be easier to bend. Cut not needed parts after bending. It will, maybe look not as from a shop, but works same. On the picture- original from left side and self-made right one.
jpsr
Mullingar, Ireland
Good job, does the trick. I'll have a go at it in the next week.
wod
yorkshire
I used 3 inch exhaust clamps on my setup.
