Ses Want Frequency Of Eutelsat
Well that rather relies upon the uncorroborated submissions of whoever made the reports to Flysat.
Retired Mod
www.timo.me.uk
Flysat list those data transponders on 2F Eurobeam and even E28A steerable. That's wrong , they are all on the 1n PE beam.
One thing I do know that that the original data channels on 11.009GHz/V and 11.186GHz/V are not on the 1N PE1 beam as I can get them in Helsinki and I can't get a peep out of 1N's PE1.
I haven't been able to test the new ones yet.
Pietclock
125cm
SE Germany 50°N/11°E
They are on the 1N PE wide beam.
jimbo2009
Dreambox 7020 software 3.6.0
Can anyone get anything on 11.464 H, 11.479 V and 11.508 V? SR is 225.00. It may be 16APSK but does anyone know the transponder numbers for these three muxes?
There is also 11.009 V and 11.186 V.
Thanks.
Thanks.
D1S D2S & Eurobird 28A according to Flysat
The third one may be Astra2F.
The first two may also have shifted to Astra by now - as they are ACM/VCM there will be few reports from enthusiasts, just those with computer sat cards really..
I think
11.009 V and 11.186 V on astra 1n
not 2f but intested here no lock
miha20
Kiev, Ukraine
I have very low signal on 11009V and 11186V(Astra 1N PE1 or Astra 2F PE), but a strong one on 11464 and 11479 (maybe Astra 1N PE2)
Pietclock
125cm
yep. 11009V and 11186V are 1N PE1 and 11464/11479 are 1N PE2.
Retired Mod
www.timo.me.uk
I don't believe 11009V and 11186V are 1N PE1 as I can pick them up in Helsinki and I can't see any other proper 1N transponders on a 1.8m dish.
Istanbul, Turkey
1N has differents footprints
Pan European2 Beam has large coverage.
These tp s are must on it.
if it was pe 2 beam in turkey need 1.5m to get lock signal
signal strong at ever more then 2f
11802h 6 db
11802h
c.n 3.1 for now
Retired Mod
www.timo.me.uk
The remaining temporary 1N transponders have now been switched off:
10979V, 11082H, 11112H, 11141H, 11156V, 11171H
Istanbul, Turkey
I have DM800 HD pvr and I dont know how can I test the signals with DVB-S2/16APSK
ACM/VCM?
Pietclock
125cm
if you want to lock /demodulate those signals, you will need a PC tuner device for either PCI or USB with a special tuner. Normal TV boxes cannot demodulate those signals.
JHMK
110cm: 19E & 13E, 110cm: 28E, 78cm: 1W, 4x Goobay Twin LNB, Faval Mercury HS-100, MicroM45
Oulu, Finland
Ouch, that hurt! Now I can receive only 48 FTA channels with Triax 110 in Oulu, Finland.
Thought first that the dish must have moved, but all signal levels on remaining transponders are as good as always...
Edit: dunno what was the problem, but now the channel search found all the lost channels again, so I take my word back. 115 channels now.
