Astra 2F: Canaries & Africa Discussion
Retired Mod
www.timo.me.uk
milestone 11
1.25m dish, sky+ HD digibox, Amstrad DRX890z, Sony vaio VGN-NR11Z/S
Corralejo
Thanks again Timo. I shall read that thread now to try to fully understand. I have not read it at all as I wasn't aware that it was likely to have any effect on our situation in the Canaries, this being the case, I therfore had nothing to contribute. In the future, I shall make doubly clear what does and does not have relevance.
Retired Mod
www.timo.me.uk
No problem, with so many old satellites, temporary satellites and new satellites with their multiple beams it does get rather confusing!
BLUEPLATINUM
Maspalomas, Gran Canaria
Basically, there is good news for everyone receiving UK Sky TV channels in the Canary Islands.
The new Astra 2E satellite has been launched. It will take six to eight weeks for the satellite to be tested and moved to the orbital position used by Sky. It is expected to "light up" in the position around the beginning of December.
After that many of the Sky channels which were lost earlier this year (when they moved to 1N pan-European which we DO NOT get here even on "big" dishes) are expected to be moved to the Pan-European beam of this satellite and will be received here on a 90 cm dish (this may include Channel 5 HD). Additionally, it is expected that the channels currently carried on Astra 2A North Beam will also move to the new beam (including ITV2 HD, ITV3 HD and ITV4 HD, most of the Sky Movie HD channels, UKTV+1 channels, Channel 4 Ireland and E4 Ireland) in the relatively near future.
Of course there is always the possibility that some of the channels will move to 2E UK spot beam (more likely to be Channel 5 HD, the HD ITVs and possibly the Channel 4 Ireland family). In my opinion, history suggests that SKY and other non-PSB-FTA carriers on the Sky EPG actively avoid UK spot TPs for their channels.
BLUEPLATINUM
Slightly OT, but since all the recent TP changes I am having trouble finding a suitable default TP to use. No EPG. Does anyone have one please?
Sent from my GT-I9205 using Tapatalk
Deso
1.2m Generic dish, Sky+ HD and Technomate TM5402 HD box.
Fuerteventura/UK
Try 12050 v 27.5 2/3 or 12207
Deso
Fuerteventura/UK
BLUEPLATINUM
I take it that one of them worked then? :-biglaugh
Hi. Sorry I can't get access to the small dish system until Saturday. I think I was using 12050 V before and that has now stopped working. I'll report back after Saturday.
milestone 11
Corralejo
My box defaults to 11.778 perfectly happily. Prior to buying the HD box we had to use 12.207.
BLUEPLATINUM
That TP only comes in on big dishes here so we have to use an alternative.
BLUEPLATINUM
12050 v 27.5 2/3 seems to work. Hopefully we'll get 11778 when frequencies move to 2E.
Report today from Member milestone 11:
BBC winter olympics channel functioning here (Fuerteventura) for snow fans. 12.552V 22000 5/6
milestone 11
Corralejo
:-bighappy You're overall a good egg Tivu.
Deso
Fuerteventura/UK
How's the signal and quality readings on that Milestone?
The sat sites have that as a 2F PE beam.
milestone 11
Corralejo
Good Deso.
Input 1 signal strength 90%
Input 1 signal quality 80%
Input 2 signal strength 80%
Input 2 signal quality 35%
First class picture, no break up, .no pixellation.
Deso
Fuerteventura/UK
Good Deso.
Muy excellente! Now, so long as they give us back what we had before, we should be laughing. There are always ways around the BBC, ITV problem. :)
milestone 11
Corralejo
I want the bloody F1.
Rickky
2.4m motorised dish. Inverto quard flange LNB 0.3 dB. Pace TD850 receiver
Egypt, Cairo
...On my way back to Cairo. Will let you know if Astra 2e delivers otherwise it's slingbox freeview and spygo VPN for me....after 10 yrs !!!
Deso
Fuerteventura/UK
It is currently on 1N PE1 beam, SD and HD, so as long as they transfer those on to 2E PE beam then we should be OK.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
For some reason I seem to have lost a bit of signal from 2f - 10964v, 10994h and 11053h are now 50% quality (was 60%) but still 75% strength on my Humax and I have lost 11023h and 11126v. Maybe caused by something else but weather here is clear.
