Astra 2E at 28.2E: General Discussion Part 2
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
As low as it gets here. Just visible in the spectrum...
Pietclock
125cm
SE Germany 50°N/11°E
East Europe beam ? :rolleyes:
Thanks qwer! I get the 11487 H 9875 feed as well now with 13 dB.
Let's see what is left after this feed is gone again. It was a broad peak centered around 11494 H. Maybe it was just the background noise of the empty transponder?
M60
Northern England
11008V 22500 ACM switched on, EU beam...
So if this is on either 2E or 2F it proves, certainly in Band C, that they can switch between UK and PE footprints for at least some of these TP's on the new satellites.
DishDick
Gran Canaria
So is 1N completely empty now?
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Yes it's ready to move or maybe is moving already?
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
11487H here 14,3dB
and 11007V same level like before (today morning, yesterday)
Tururu
Assembled with recycled parts
Recycled as the owner.
The two datacarriers on 11464 / 11479 are gone.
But there is a new one on 11494H which is very weak here, so I cannot get a SNR. Is it on UK Spot beam ?
For Madrid 100cm dish C/N 18.9dB
Por Madrid con 100cm antena C/N 18.9dB
Pietclock
125cm
So it is the Europe beam, they just needed a while to get to full power it seems...
11.008V back on 1N PE ??
C0re
Ede
VU+ Solo SE
That's very unlikely. Must be Astra 2F european beam?
dxsat
skyinmadrid.com
Snap's setup: (In Spain) Humax HDR, Prodelin 1.8m dish + Invacom QDF-031 + CM feed, (In UK) CallFlow VDSL + EE 4G, Sky Q, YouView HD, Mac OSX, iOS
UK: Tonbridge, Kent. Spain: Madrid.
Is there any reports of 2E reception in Malta, if so what sized dishes? I guess it's way too far south and east of the footprint.
Only one report, of loss on a 1.8 metre. No reports yet of success, or anything further out, apart from one woman who claims to have 2E spot in Lindos, Greece on dish extended to 3.2 metre. She has a further two 2.4m and four other dishes at her bar with varying degrees of success on Sky's pay channels.
Fisty McB
See my signature...
County Tyrone, N. Ireland
''many cold-spots''. But why is that. Down here in Malta we can receive Italy's Terrestrial Rai Broadcast, Mediaset's and a lot more from small Italian stations although these stations are not intended for us and more than 100km's away. Surely it is a problem of putting more repeaters at strategic points! Anyway Tivu as I said my opinion only.
Most of that approx 100km will be across water with little or nothing in the way of obstructions.
In many parts of the UK, terrain can make coverage difficult, especially in more isolated areas with a very low population where a relay may not be economically viable. In the past many self-help relays sprung up to fill these gaps but these day with satellite being available, most of these went blank at DSO.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I agree with you that from the south of Sicily to Malta is just the open sea, but these Italian transmission originate from Palermo mostly, which is in the Northern part of Sicily and therefore if one would measure the total distance it would be in the region of 258km or 160miles with most of the transmission being over Sicilian terrain. Anyway thanks for your input.
Has 1N started her transition yet?
And do we know for sure whether 2E will nudge from 28.35 closer to 28.2 after 1N departs?
Or does the 28.5E slot becoming vacant mean 2E can happily sit where she is now?
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
Center of box ,window center is 28.35.
and will be there at least 25.02.14..
ses.com
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
So am I right in saying that Eutelsat will be taking capacity on an SES bird @28.5e?
M60
Northern England
Yep, 12x TP's, no date for this has yet been set though.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
I would like to know that too.
