Distance between LNBs
Pride Of Cucamonga
Valencia (city)
I use those here and they are great - easy to adjust and pretty firm as long as you do the bolts up tight :D
The only thing to watch is some lnbs dont have a long enough neck to allow those to attach once the lnb holder on the dish is on.
Retired Mod
www.timo.me.uk
I have the exact same LNB holder on a 90cm dish and it does about 12-14 degrees so it might just fit on a 1.1m, or it might not... either way it'll be close.
Pride Of Cucamonga
Valencia (city)
Cheers. I'll be using an Inverto permium and ultra (both dual feed). Is this model wide enough for 9 degrees?
Retired Mod
www.timo.me.uk
The LNBs will be at the opposite ends of the bar so any type of LNB would fit as long as there is enough neck to strap the holder to. The only question is if the bar is long enough for a 1.1m dish (the bigger the dish the further away the LNBs will need to be).
Pride Of Cucamonga
Valencia (city)
Anyone know how to calculate?
For 7 quid just take the punt. It'll come in useful elsewhere at some point if it doesnt fit :D
Retired Mod
www.timo.me.uk
True, I have a couple of spares in the cupboard, just in case I need them...
Fisty McB
See my signature...
County Tyrone, N. Ireland
Or get a second, identical one and using two of the large securing nuts & bolts of one of the holders to join both brackets together to extend its range.
I remember seeing a video on YouTube from an Irish satellite dealer using such a bracket on either an 80cm or 90cm dish to get 28 East & 9 East for Saorsat and Freesat/UK FTA channels using two lnbs (Ka for Saorsat) so I'd say if that bracket can cover nearly 20 degrees on that size of dish, I don't think 9 degrees on a 1.1m dish should be a problem. But that's just an educated guess from myself.
Edit: YT video in question with 80cm dish...
Retired Mod
www.timo.me.uk
A good idea. These bars are fairly flexible too so you can carefully shape them to the right angle so the LNB looks at the centre of the dish.
Pride Of Cucamonga
Valencia (city)
Cheers for this - that's a lot of degrees of separation!
ched999uk
zone 1 sky type dish with quad lnb @28.2e, zone 2 sky dish with octo lnb @ 19.2e and Humax Foxsat HDR
Sunny Blackpool
Can't remember where I found it but:
Let L= dish focal length - if you don't know then use centre of dish to lnb
Let a = azimuth angular difference between offset sat and focal one.
Let d = spacing of LNB (from centres)
Equation:-
d= L x tan(a)
Piltdownpaul
No.1 Spike Milligan Fan
satelliteman
Impressve stuff there.
ched999uk
Sunny Blackpool
Piltdownpaul: thanks very much for those images. I am only using zinwell quad and octo lnbs with 60mm caps but your images do convince me that I should be able to get 19.2 and 13 using my lnbs on a zone 2.
Thanks.
