New C band LNB
remlap
Wales
Might be interested in one of these and give it a try with my AV-COMM polariser. Something for another day with a bit more money and better weather.
Nice to see something live up to the hype.
Costactc
Canada
VS already received his :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Indeed I have ..
Cheers Costa
I suspect proper setting up an testing will have to wait till weekend but I have at least mounted it on Christina..and it is working.
Kveys
Southern Finland
Titanium C1-PLL after few days testing period; Yes, it´s better than any Lnb earlier. It doesnt make miracles but some new channels and better signals though. Specially with linear channels. Here in Finland you can find many linear satellites 66E -83E.
Slight disappointment with circulars. Yep, also better signals than earlier (ESX241) but for instance every freq. from 5W were better previously. Maybe and only maybe its cause my former Lnb with homemade depoplate was perfect. This earlier best depoplate dont work good enough with Titanium unfortunately.
Example: CRTV Cameroon (5W) was 11.8 dB now with Titanium 9.7! But Tunisian mux (20E) was 4 .7 dB and now 7.2dB! Sure I might learn how to make also suitable depoplate also for Titanium, who knows..?
Linear signals are partly unbelievables. First regional beam freq. from Thaicom 5 (3921V). Take a look at footprint! Some new channels also from 68.5E/83E. Somehow Kolkata ch 4180H been my goal and busted now:)
Other disappointment was band. Yes we knew from the beginning that it is "only" 3.7-4.2 GHz. In practise I got 3600H (78.5E) but thats last. No life from 3596L (49E). Frequencies under 3700 GHz are weaker than what they should be. Thats why I must purchase also widebeam (3.4-4.2 GHz) Titanium later.
Anyway, I can really recommend this new Titanium for all enhusiasts. Thanks Costa and also thanks for other mates who ordered this also!
Costactc
Canada
You guys really got me going now and I'm starting to get the itch but I would definitely want widebeam but it must be dual for both my coax.
Kveys
Southern Finland
Costactc
Canada
Thanks bud but there out of stock for the dual, would like to slap one of those on my 3m bud. I just sent an e-mail as to its availability.
kingkad
3.8m Prodelin Offset.
London
C1W-PLL C-band Wideband LNBF will be in the UK soon...Few weeks i've been told.
Looks very familiar
adonis1
C1W-PLL C-band Wideband LNBF now available from Titanium, just ordered:)
Me too , and i hope to get it in to my hands , in 5 days .:)
Costactc
Canada
Got an e-mail from Brian as to the availability of the dual wideband lnbf. He said they will have limited quantities this month and I told him to put me at the top of the list.
pride21
Sandown Isle of Wight
hi all tried this Titanium C1-PLL c-band lnb against the EX241 the PLL has gain on some channels where as the 241 has gain on other channels,other channels also came in with the PLL but did not with the 241 and vice versa,its the strangest lnb I have come across, the placement of the lnb and the scaler are important to get the best out of the PLL I have kept it on the dish to give it a good test.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Same here using a 1.2 Dish, especially the circular freqs which seem to loose out.
Costactc
Canada
Just wondering if improvements are on the linear side with this lnbf? I have a seperate dish that is circular devoted.
pride21
hi Costactc on linear the gain was a bit disappointing for example on the EX241 I get cholusat at 43W with 51% quality but with the C1-PLL it goes down to 47% quality other sats much the same.
Kveys
Southern Finland
Interesting, because here are definitely linear signals better than earlier. Many new frequencies from 68.5E, 78.5E and 83E with C1-PLL. BUT on the other hand no lock from 37.4W 3748H/3755H. And also so far only locked freq. from 40.5W (circular) was 4045R and now not even weak signal anymore with C1-PLL?
It could only coincidence but my western signals are poorer now and eastern better?!? :) Dish (polar mount) moved? Yes essentially possible but, but no I dont think so.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
I got Freq 3692 R - 1400 - 3/4 on 10E with an SNR of 37% but no other Circular Freq on 10E - 3.1E - 5W or 11W.
What I got with a 78% Snr was on 3.1E....Freq being 3764 - H - 20330 - 2/3. Dish being 1.2.
Are you guys using a bigger Dish?
Costactc
Canada
It will be interesting to see how it stacks up with my bsc422 lnbf.
adonis1
For first time "Yunnan International Channel" 3775 H on Chinasat 12 @ 87.5° East , with titanium satellite LNB .
