aproblem with zinwell zk-j22n
fs789
truman premeir plus
spark system
palestine
hellow,
i have bought aprime focous lnb (( zinwell zk-j22n )) to receive weak signals which are out of our range (( astra 1n // astra 1L // astra 1kr )) , but unfortunately i did not receive any weak signal.
http://www.zintech.com.tw/uploads/product/ZK-J22N WP.pdf
do you have any information about this lnb?? is there any one have used this lnb??
please help me to instasll this lnb in aproper way.
my dish is 180 cm prime focous and i live in palestine
Mickha
North West
Unfortunately a LNB will only help slightly, with weak signals, only a larger, good quality, dish will really help to bring in weaker satellite signals, if they are receivable at all.
Which channels are you trying to get, on your dish?
Trying to work out the maps, for your location, you might be able to get 1M, the Europe wide beam, but I'm not too sure of the other satellite beams.
Have you checked out IPTV receivers?
Unless you have an enormous dish the west European beam channels on 19E are not receivable in your area.
You need to think about getting them via an alternative source
From the PDF: Noise Figure 0.9 dB (Typ.)
:eek:
fs789
truman premeir plus
spark system
palestine
thank you for assistance
some one has advised me to buy an lnb called (( INVERTO BLACK PRO)) for reception of the west European beam channels on 19E . do you think that this helps me ??
fs789
truman premeir plus
spark system
palestine
please what do you mean by enormous dish ???
and also what do you mean by 10 fixed dishes??
please what do you mean by enormous dish and 10 fixed dishes??
Terryl
Custom built PC
You can go to the following site
http://www.satbeams.com/footprints?norad=37775
it has an active footprint map for Astra 1n, you can also select the others, you can zoom int your location, then click on it, if you are in one of the beams it will give you an estimated dish size needed for your location to get a good signal on that satellite.
If you are outside the coverage area for that satellite (it's receivable footprint) you may be out of luck, and as stated a newer lower noise floor LNB will not get the satellite if you need a 4 meter dish or larger to do so.
fs789
truman premeir plus
spark system
palestine
Terryl
Custom built PC
Did you go to the web site I posted and check to see if you can see that satellite at your location?
And what size dish it recommends?
As for the Inverto Black Pro LNB, if you can't see the satellite at your location with your current dish and LNB then changing to a different LNB may not help you very much.
You may be outside the coverage area for that satellite.. or your current dish may be too small to properly receive the satellite at your location..So check with the web site I posted before you go out and buy something that may or may not work.
fs789
truman premeir plus
spark system
palestine
i have gone to the site ,but unfortunately i did not see the satellite astra 19e (( 1l/1n 1kr )) at my location. i am very sad . so, what is the solution?? is the inverto black pro good or not for this purpose??
Not if your dish isn't big enough. Changing LNBs has the potential for minor improvements (If implemented correctly), but is no substitute for increasing dish size.
fs789
truman premeir plus
spark system
palestine
what is the minimum dish size required ???
my dish is 180 cm prime focous .
And neither will it work properly with a prime focus dish
Mickha
North West
Have you considered something like an IPTV receiver, to get the channels, as I mentioned earlier?
fs789
truman premeir plus
spark system
palestine
why it wii not work properly with a prime focus dish ??
are you sure??
Terryl
Custom built PC
well if your outside the footprint for that satellite then you may need a 5 meter or larger dish (there may be some side scatter to pick up) but you may be out of luck for that satellite.
Try looking into the IPTV receiver like Mickha mentioned.
Mickha
North West
IPTV receivers do not use a dish, to get a satellite signal, they use an internet connection.
For the west Europe beam 19E channels you might start to stand a chance with something over 5m!
With just a 1.8m dish - forget it - no chance with any lnb.
So lets start exploring other options.
Which channels are you most wanting? Many of the German fta channels have web streams
fs789
truman premeir plus
spark system
palestine
but this needs high speed of internet . i have aspeed of 2MEGA . is this sufficient??
also, my receiver contains IPTV network, but how can i use it??
i think that i need aserver in this case and pay money.
fs789
truman premeir plus
spark system
palestine
But afriend living in egypt, which is also out of foot print, has told me that he uses inverto
black pro on 1.8m dish and has succeeded in receiving the west Europe beam 19E channels.
and other friend has modified an lnb and aded special feed horn .
http://www.bestsatinfo.com/2013/04/home-made-ku-band-prime-focus-lnb.html
