- Oct 21, 2006
- See signature
- North Somerset
Yes, indeed a Prodelin made Echostar 120cm dish.I think its a Echostar 120
edit : I am shure it is !! I have the same
@Trust1: What's with the angle? Is it mounted 90 degrees tilted?I think its a Echostar 120
Go for it! It should work very well, and includes a polar mount that seems to have been fixed with the metal bar.This seems to be some kind of old CM models, and not so far from me. Is this good if I bid on it lets say for 50 EUR?
Years ago I made this@Trust1: What's with the angle? Is it mounted 90 degrees tilted?
Amazing stuff!Years ago I made this <snip> a clockwise rotating dish and noticed that with a skewed dish there was some improvement to the signal .
So I modified that 1.2 m Echostar Offset with a extra rotating axle in line with the elevation .
Made also motorskew for the lnb to keep that on the right level
Tested it at Nilesat but no improvement with this dish .
My conclusion , the small ex BSB dish was more square and with the corners in line with the H en V there was some profit .View attachment 67059 View attachment 67060
That, to me, suggests that the f/D ratio was not correct for the LNB. Specifically it was more correct for an ellipse touching the corners rather than an ellipse fully contained within the dish.My conclusion , the small ex BSB dish was more square and with the corners in line with the H en V there was some profit .
Yes, that's the one I'm referring to in http://www.satellites.co.uk/forums/...big-dishes-for-sale.45717/page-77#post-894006 ;)1.2m CM/polarmount/actuator/76mm pole/hypex brackets 301267179262
That''ll be moonbase's dish, previously posted here:Another prodelin 1.2m
131272165365
http://www.satellites.co.uk/forums/threads/echostar-1-2m-dish-polar-head-ground-stand.161671/
