Vipersan
Emmett Browns Ghost
- Jun 29, 2009
- Age
- 66
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Thanks Llew ..
Looks like I was right then about the waveguide diameter being around 10mm inside diameter..
Much the same as the inverto in this regard..
Is that a thin stepdown just inside the first ring > waveguide ? about a cm down the throat ?
the 2mm thick rings are a surprise as the invertos are only 1mm ..
Cheers for the dimensions Llew ...
I may well attempt something at a later date.
rgds
VS
rgds
VS
