unstable reception
Pilipino
Baguio Philipipines
180cm dish, technosat t-888 plus or Bollt 630 s receivers
Baguio N16° 24' E120° 34' Philippines
Hello to ALL.
I'm trying to receive TV5 Monde Asia trough ASIASAT 7 3760 H as the power and quality are unstable I was advised to change the LNB, it did not improve! Then I changed the receiver, still no improvement.
I do no more know what to do! May I ask for suggestions?
Best regards to All. Pilipino
Terryl
Custom built PC
How old is the system (dish and coax) the dish could be out of line, it may need to be tweaked.
The coax if it's old could have a cracked PVC jacket, this would let water in, water can cause BIG problems on the satellite signal to the receiver, if the center conductor is copper plated steel it can also rust, this can also cause a drop in signal, check all connections for corrosion or rust on the center conductor.
Is there anything else in-line from the LNB to the receiver?
A ground block could cause a drop in signal if it has gone bad or has corrosion on the connections, any coax splices in the run of coax? If so then check them.
Do you get any of the other C-band channels with acceptable results??
Its also possible you are suffering from local interference - C-band is under threat in many areas for other uses, especially wifi applications.
Pilipino
Baguio Philipipines
Hello Terryl.
Many thanks for your reply. Every things is NEW! Is it possible that the LNB gain is not enough? ( conversion gain 65db. gain flatness 0.5 db/36mhz) the coax is very short just for adjustment of the dish, i'm using my receiver to align the satelitte, I have a good power and quality signal but it goes to 0 and Ok again (Instable)
Best regards
Pilipino
Baguio Philipipines
Pilipino
Baguio Philipipines
Hello Analoguesat
No I don't receive other C band channels. Every things is NEW! Is it possible that the LNB gain is not enough? ( conversion gain 65db. gain flatness 0.5 db/36mhz) the coax is very short just for adjustment of the dish, i'm using my receiver to align the satelitte, I have a good power and quality signal but it goes to 0 and Ok again (Instable)
Best regards
Retired Mod
www.timo.me.uk
Have you tried another reciever? Do you ever get to see a picture or scan in any channel names while the quality is good?
Terryl
Custom built PC
Hello to ALL.
Have you checked with satbeams.com to see if you can receive that satellite at your location?
Try the link below, use the "C" band global footprint, (selected in the pink and purple area at the top of the map) then zoom into your location and click on it, this will give you an idea on the size of dish needed to properly receive that satellite at your location.
http://www.satbeams.com/footprints?norad=37933
Pilipino
Baguio Philipipines
Thank you Terryl.
I could see that the C band is OK for my location, the K is not.
Regards
What size dish are you using? C-band needs much bigger dishes than Ku
Pilipino
Baguio Philipipines
Hello Analoguesat. Many thanks for your post. I'm using a 1m80 (6ft) dish.
But since I bought a "NORSAT" lnb very expensive, it avoid the interference, responsible for the problem. IT'S OK NOW.
Many thanks to everybody for your help. Best regards. pilipino
Ah good glad to hear you are sorted.
Unfortunately local interference on C-band is only likely to increase - there are a lot of comms firms wanting the spectrum for their own purposes.
