68.5 East C band result
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I did a blindscan and am receiving 216 (most of them encrypted) services at the Moment on 68.5E C:Band. Lots of news channels mushroomed.
Kveys
Southern Finland
4003V 7200: Satlon news. Flysat missing it but Lyngsat updated already.
Focus - is that from Burma??
Kveys
Southern Finland
^ India. These been earlier on 91.5E only. There´s also Focus Bangla (91.5E).
Anonymous_1
4184 V
Comedy Central HD
Big Deal TV
PS: I'm safe, picture are uploaded on your server :-buttkick
Feedsat_Dxer,
Which of your dishes did you use to capture the C Band feeds from 68.5E ?
Thx
Winegard Micromesh 3.1m or Channel Master PFA 3.1m ?
Would you please be able to test for some signals for me from 68.5E?
They are encrypted but I just wish to know if they are able to be received, 3712 H, SR14454 and any feeds on 3782H and 4175H?
Thx
Anonymous_1
both antennas, but a litlle bit stronger with the Channel Master with the Titanium.
Thx
3712 H , no problem, regular programmes always "on"
Here is one of my last scans but 3782 and 4175 were off, but usually when it's on , I have no problem to lock them, especially 4175 H, maybe 3782 is the weakest, I need to confirm this next time this will be "on", I can't check this for now.
PS: both scans are not from today and were not done the same day
CM:
<Another scan with the Winegard (with dielectric plate inside the polarotor):scanh.JPG
regards
Feedsat_DXer,
Many thanks for confirming the signals I asked about are able to be received.
One last couple of questions if you can please help?
1. With your Channel Master 3.1m dish, what LNB are you using, I saw you referred to "Titanium" in your above post, is this the LNB?
2. Approximately what latitude are you at just so that I can see if you are in a stronger zone for the beam compared to Southern UK?
Rgds
Anonymous_1
1: Yes the Titanium C1W-PLL
2: According to the offcial footprint, in France and UK, we have the same beam,but don't forget most of the feeds are weaker than regular channels.
@moonbase : Back to this post, 3782 H is active and locked
Feedsat_Dxer,
Thanks for the confirmation.
If I read your Signal/Noise correctly at 8.4db from your 3.1m dish it looks like anything smaller than a 3m dish in the southern UK would probably not get a lock?
Rgds
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Jaya Network FTA at the moment Freq 4130v
Anonymous_1
Feedsat_Dxer,
Rgds
Yes, probably; the dB failure for a 8PSK 3/4 is around 7.8 dB I think
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
