stephen211270
Technomate TM5402 M3
Maxx Digital Satellite Dish 1.1m
NVERTO BLACK ULTRA HIGH GAIN SINGLE LNB
SUPREME DARK MOTOR LED METAL GEAR DiSEqC 1.2 / 1.3 USALS
- Liverpool L4
http://en.kingofsat.net/find.php?question=OTE&Submit=Zap
http://www.lyngsat.com/Eutelsat-9A-and-Ka-Sat-9A.html
Yes. he is in satellite set up and needs to go into motorised setting where it shows the transponder and strengths.I´m not an expert on the Technomate boxes, but shouldn´t the LNB frequency be showing something other than 00.000?
Yes looks like 9E, but frequencies and symbol rates don´t tie up, so think something wrong with the box settings ( unless like the VU+ solo SE I have it is giving false info when in the channel )Looks like your dish is pointing at 9E, judging by the channels:
Code:http://en.kingofsat.net/find.php?question=OTE&Submit=Zap
try some of the other FTA channels, on 9E:
Code:http://www.lyngsat.com/Eutelsat-9A-and-Ka-Sat-9A.html
What I meant was that in the second pic file in posts 101 ( top page 6 ) It shows the lnb as universal, but no frequency range set, or is this normal for this box on that page?Yes. he is in satellite set up and needs to go into motorised setting where it shows the transponder and strengths.
Hi so locked it down and keep it there at 1W Apologetics I have probably been told this many a times head is up my bum right nowWell done, now put a pencil mark on the pole and motor bracket so you know how to get back to 9E in case you get lost, then you need to move the dish and motor round the pole slightly W not much just a bit at a time until you lock 1W.
OK, lets start at the very beginning! do ray me!Hi so locked it down and keep it there at 1W Apologetics I have probably been told this many a times head is up my bum right now
I,m going to buy a satellite finder at least that way I know its done correctly
Hi martin I do have one of them this one. what I would like to do is get rid of poll 1 and put the dish on poll 2 a sat finder will save me a lot of massing aboutYou would be better buying an imclometor, a sat finder will only do what the STB does at the end of the day, if you cant get it right your angles are out/something not level/both.
http://www.satsig.net/azelhelp.htm
has anyone used DishPointer Pro app is it any good
