Newbie Here Advice on install
stephen211270
Technomate TM5402 M3
Maxx Digital Satellite Dish 1.1m
NVERTO BLACK ULTRA HIGH GAIN SINGLE LNB
SUPREME DARK MOTOR LED METAL GEAR DiSEqC 1.2 / 1.3 USALS
Liverpool L4
right I have got this up
Mickha
North West
Looks like your dish is pointing at 9E, judging by the channels:
http://en.kingofsat.net/find.php?question=OTE&Submit=Zap
try some of the other FTA channels, on 9E:
http://www.lyngsat.com/Eutelsat-9A-and-Ka-Sat-9A.html
TJExcalibur
Out of this world.
Southern England
I´m not an expert on the Technomate boxes, but shouldn´t the LNB frequency be showing something other than 00.000?
Yes. he is in satellite set up and needs to go into motorised setting where it shows the transponder and strengths.
Archive4
Yes looks like 9E, but frequencies and symbol rates don´t tie up, so think something wrong with the box settings ( unless like the VU+ solo SE I have it is giving false info when in the channel )
Archived-1
Persona non grata
uk
Well done:-applause:), now put a pencil mark on the pole and motor bracket so you know how to get back to 9E in case you get lost, then you need to move the dish and motor round the pole slightly W not much just a bit at a time until you lock 1W.
Archive4
What I meant was that in the second pic file in posts 101 ( top page 6 ) It shows the lnb as universal, but no frequency range set, or is this normal for this box on that page?
TJExcalibur
Out of this world.
Southern England
BBC World on Thor is 10778 H 24500. Strength 72%.
Go into motorised set up. Choose Thor and then 10778 H 24500. If its not there go into
He needs to scroll across to choose the frequency.
stephen211270
Liverpool L4
Hi so locked it down and keep it there at 1W Apologetics I have probably been told this many a times head is up my bum right now
Archive4
OK, lets start at the very beginning! do ray me!
No!, not that one.
DO NOT ADJUST THE DISH TO MOTOR MOUNT, for now. Mark the position of the dish as it is, so can return to 9E if all else fails. Loosen the motor mount bolts and rotate the whole assembly west. ( That´s to the right when behind the dish ) I know this sounds strange when you see Carol doing the weather on BBC in the morning and the West Country is to the left, that´s because it´s a north aspect picture, and your dish is looking south to the Clark Belt. Move the dish very slowly with the sat box looking for 12418V 28000, fec 7/8. When you find a good signal, stop and scan. You should find Al Jezeera, Sky News and a couple of others. If not, try again.
When you find A J adjust dish elevation to get max signal.
Report back then and we will advise further!
stephen211270
Liverpool L4
I,m going to buy a satellite finder at least that way I know its done correctly
which one is the better one out of SATLink WS-6933 and SATlink DVB-S FTA Data WS-6906
Archived-1
Persona non grata
uk
You would be better buying an imclometor, a sat finder will only do what the STB does at the end of the day, if you cant get it right your angles are out/something not level/both.
stephen211270
Liverpool L4
Hi martin I do have one of them this one. what I would like to do is get rid of poll 1 and put the dish on poll 2 a sat finder will save me a lot of massing about
Archived-1
Persona non grata
uk
If its like the one I bought it was 2 degrees out, you need to start at the very beginning, pole level both ways, dish set on the motor bang central azimuth and elevation set correctly, you must have something set wrong, these need setting bang on near as dam it, if anyone of them is out you wont track the arc and no sat meter will help you.
http://www.satsig.net/azelhelp.htm
stephen211270
Liverpool L4
if I where to upload some picture could you tell me if I could get away with removing poll one on picture or would I still need the hight ??
Archived-1
Persona non grata
uk
When I said if the bottom of the dish to be level with the top of the roof, was when you was going to put it on the chimney, you have a lot of steel work there and could easy be out, I would take it all down and just use one pole, get it setup and see what you get, if your missing out at a later date put it higher if needed.
stephen211270
Liverpool L4
I should have used one of there's instead of the T brackets
stephen211270
Liverpool L4
has anyone used DishPointer Pro app is it any good
Ghostleader
Glasgow,ish!
The fly feckers asking for money for Dishpointer these days? Mad.
Sent from my T5 using Tapatalk
Archived-1
Persona non grata
uk
This is as accurate as your going to get without using a compass. you have all the information to get this set up correctly you just need to go through it step by step, and if you don't get it right start at step one again and again,
Step one is firstly making sure the pole is level (two ways) and your angles are set correctly.
Newbie Here - Advice on install
