UK spot beam variances in Spain ( and elsewhere )
Archive4
As many are aware you can get most of the UK spot beams on a 1.2 m and above dish in my area of Spain, with the exception of some of the ITV HD channels, and it would seem a few others such as 12129 V which is much lower than the others.
I´m going to run some tests across a range of txp´s and would like to know if others here in Spain, or other fringe areas are having the same problem.
For example on 12129 V my Fam 1.8 is only receiving 6.9 dB while 10817 V is 10.9 dB
Would also like to know if there is a big difference in the intended target area, ie, variation between Southampton and Glasgow.
Thanks to all who " chip in "
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
60°31'02.4"N 14°16'40.7"E 1.2m IBU
12129V 7.6db
10817V 8.5db
4wd
Getting the picture
5 W, 9-13-19-28 E
10817 v 10,9 db
12129 v 10.7 db
Solo2 at time of posting, before the evening drop really sets in (similar drop for both these transp.)
woborny
Gandia - 70kms south of Valenica
1.8 Marafa:
10817 13.2db
11053 11.0db
11097 10.5db
12129 10.5db
80x85cm
10817 7.7db
11053 n/a
11097 n/a
12129 6.5db
Archive4
Looks like Gandia is not being as badly effected as here ( Formentera del Sugura )
1.8 Famaval
10817 v 10.5
11052 h 9.7
11097 v 10.3
12129 v 6.4
1.8 Laminas
10817 v 10.5
11052 h 10.8
11097 v 10.8
12129 v 7.0
strange one, 11343 v 10.7 on the Fam, 11.5 on the Lam
Will check to see if spectrum can see anything causing local noise, but doubt it is the problem as I was getting similar levels ( and variance ) on another 1.8 I was working on about 6 km further away in Quesada today.
For reference, the 1.2 can only see 10817 V 9 dB, nothing on any of the other 3 listed above 11343 v 7.5 dB
Off to airport now for SWMBO so will play a little more later.
Lampard25
Nr Vera
www.mytvcinema.com
Sky HD , Humax freetime pvr , spider 9000hd
Nr Vera Spain
Hi 12.129 was only possible around january & that was on a 2.4 fam not seen it since here near mojacar
Archive4
10817 v 10,9 db
12129 v 10.7 db
Interesting that the northern fringes are seeing much less variation than we are south of target area.
Have just checked again now and 12129 V is up to 7.5 dB 10817 V also up, now 11.1 dB.
11052 H is unchanged, but 11097 V has dropped 0.5 dB. Hmmm?
Nalleman
Motala Sweden
Sweden
Located in southern parts of Sweden I too see a big difference (values during the evening):
12129 V: 9,9 dB
10817 V: 12,2 dB
12304 H: 8,1 dB (by far the weakest)
11052 H: 9,7 dB
11097 V: 11,2 dB
Archive4
12129 V: 9,9 dB
10817 V: 12,2 dB
11052 H: 9,7 dB
11097 V: 11,2 dB
Hadn´t checked 12304 H, until now. Here it is only 0.3 dB lower than 12129 V , currently 6.3 and 6.6 dB respectively. Your difference is still less than ours, I currently have a 4.5 dB variance between 12129 V and 10817 V.
Hoping LP will have a chance to have a look soon as he is about 18 km further south of me.
Retired Mod
www.timo.me.uk
In Maidenhead on a 60cm dish, TM6900 quality readings:
12129 V: 89%
10817 V: 88%
12304 H: 89%
11052 H: 89%
11097 V: 90%
2G Europe tends to be the weakest, eg 11224H: 82%
2E/2F Europe are slightly down from UK spots, eg 11778H: 85%
Archive4
Had a few comments today, so now I´m back at the castle decided to check 12129 V.
Only 6 dB on the Fam, 6.5 dB on the Laminas, about 1 dB down on the readings a few days ago at roughly the same time.
If it keeps on like this it will be a no go even on a 1.8 in my part of the world!
I can probably get the UK beam on a medium sized pizza here.... Well, definitely a saucepan lid (done that, T-shirt etc.).
4wd
Getting the picture
5 W, 9-13-19-28 E
Seen from north, evening time + rain.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
As we speak Brian....channels are pixelated badly on 12129 V.......1.8m. :(
Archive4
Thanks LP, down to 6 dB on the Laminas at the moment, gives me about 1 dB grace.
You´re only 18 - 20 km down the road, so the drop off is steep at high frequencies. Wonder what H can see ( big hint )
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
............Wonder what H can see ( big hint )
Not heard much of late Brian but hope all is well with himself.
........at the mo watching the snooker !
Best wishes. :):)
woborny
on the 80x85 12129 is still at 6.5 for me....
Archive4
Checked this morning on the 1.2 motorised dish and getting 4.9dB slight pixelation, but nothing on the 1.2 a few days ago. Looks as though signal may have increased slightly. Will check on the 1.8´s later when I connect them up to the box.
