Archive4
As many are aware you can get most of the UK spot beams on a 1.2 m and above dish in my area of Spain, with the exception of some of the ITV HD channels, and it would seem a few others such as 12129 V which is much lower than the others.
I´m going to run some tests across a range of txp´s and would like to know if others here in Spain, or other fringe areas are having the same problem.
For example on 12129 V my Fam 1.8 is only receiving 6.9 dB while 10817 V is 10.9 dB
Would also like to know if there is a big difference in the intended target area, ie, variation between Southampton and Glasgow.
Thanks to all who " chip in "
