1.8 dish help needed please
redrum
techonmate 1500 ci+with 80 dish just got 1.8metre to but up hopeing to get nilsat for football
portsmouth
i have had a 80 cm dish for over a year and have just brought a 1.8 merte dish so i can pick up nilesat i live in portsmouth have done some reading and some post say i might struggle to pick up nilesat can some please help.
CROSSBONES
S.Wales
What make dish is it? What lnb and feed are you using?
johnwilliam1
technomate 1500
strong 4375
pace digi box
triax 1.1, triax 88cm
UK.
red rum,
when i had a 1.6mtr dish i got the verticals and thats from hartlepool in the north east, so realy you should pick it up, possibly the horizontals as well
At a guess its one of the 99 quid Maplin dishes. (Horribly low quality and have a nasty tendency to buckle in winter storms!)
Well if it is, then spend a few hours assembling the reflector, ideall on a very flat floor surface, one of our members RD100 has managed to get one to perform reasonably, but said that setup is crucial. The dish is i believed supplied with a standard LNBF, a C120 and feedhorn would probably produce better results.
If it isn't, would be interesting to know which brand it is. :)
redrum
portsmouth
it is a IRTE s.p.a made in italy i have order a c120 and a feedhorn and a v box 2 as the dish and moter is very old have been told this is what i need hopeing to get tomorrow to start geting it setup just hopeing it is big enough for nilesat so i can get the football cheers redrum
satelliteman
Look forward to reading the results Redrum, although I had the impression it was going to be a fixed system.... don't know where that came from :D
redrum
portsmouth
yes mate will let you know hope quite soon have you heard of the dish.
cheers redrum
wod
yorkshire
on the feedhorn did you buy an adjustable one so you can get the best setting for the dish, the invacom feedhorn is a good one.
if the motor is an actuator then you might need to change it for a new one.
redrum
portsmouth
not to sure want i have ordered.the motor is a superjack ll +
wod
yorkshire
the motor should look like this if the dish uses a polar mount
CROSSBONES
S.Wales
The IRTE is a very good dish. There is a matched feed horn for the IRTE, see if you can get hold of one. It will perform much better with the matched feed.
-http://www.irte.it/I/a_csat.htm
redrum
portsmouth
yes wod it does look like that won when rain stops will try and set up let you know how i get on
redrum
portsmouth
set my 1.8 dish up and have pick up nilesat got all the showtime channels and sports channels signal strength is between 45 and 65 so i thing when it rains might not get a picture.
CROSSBONES
S.Wales
What feed horn did you use?
redrum
portsmouth
not to sure but dont thing i change the feed horn just but the c120 on.
i im bretty new had this so my sound a bit thick.my next thing is to get a viewing card or keys what is my best option look for key and could only find old one so i am guessing they dont come up very often can someone help.
CROSSBONES
S.Wales
So What feed horn did you use with the C120 lnb?
Regarding the keys, just use the latest patch for your Technomate;)
Dont you use a spell checker?:-rofl2;)
redrum
portsmouth
I'm using the original feed horn that came with the dish.
That's why I don't leave many posts as spelling and grammar not my strong points. (I get the wife to do it when she's about!)
renibacterium
Visit site
You will have no problem in Portsmouth getting the horizontal channels on 7 W with a 1.8m IRTE dish. I am in S W England and have a 2.0m IRTE and get all the horizontal channels.
