11670H 1700 no signal
frund
triax 1.1 tm 1500ci+ dm patch. Moteck 2100. Intel 4300 based pc . LG7500. 32" lcd
Wales. UK.
Is it possible to get the above ? I would to get the canaries tv . thanks :( should be 11676 h
Which satellite ?
Go on gi's a clue O-Ha
L.:)
sometimes it happens,
mine is strong 3620, LNB is also strong, with some frequencies there is no response.
it says weak signal. and its in the red zone.
but I don't know what's yours.
choose the satellitename
the frequency
Sym rate.
the pol.
and FEC V-PID
it should be OK (85 -90) per cent.
Arbi
I'm on hispasat motorised may need a tweak took me ages to get it right I go between 28e to 30w generally good signal 3db lnb. 11676h red 11682v 40%, 11731h 68%, 11771v 74% this is my best signal.
11574V 27500 is the strongest I can find here.
11508V 09547 is the weakest.
Try those for tweaking .
L.:)
I did not have that tp so I have added it..no signal. My tp onboard list may be in need of updating but thats another thing. I don't seem to have anything below 11682v3800 40% sooooo look out dish here I come.
Well I've been out and had a fiddle. 30w is up to 87% but some lower tp's don't show a signal at all 11574v2700 for one but I am now getting a 50% signal on 11615 and 60% on 11535 so more channels have opened up and I'm still ok on 28e 13e. It's freezing here in Wales so that will do for today. I have just realised the tp [88 lyngsat 11676 h] is 'impassible' anyway. thanks
Well done mate :)
What's wrong with 11676 then ??
L.:)
I thought the encryption was well locked ? is this right. Canaries tv. powerVu. thanks.
Yesterday, the adjuster was to make some changes to our reciever and upgrade it, said me that with this receivers we cannot get any frequency whether in satcodx or other sites it seems ok.
The satellite itself doesnot have the support over those countries or such a places. that's the reason why?
Or the signal is weak or no response to what you are searching for?
Regards.
