Tried dr.hd d15 but no joy...however I may have been to late.Hi,
There's a 16APSK testcard currently active for the BBC on 16E if anyone wants to test equipment.
12701 V 7200 2/3 DVB-S2/16APSK.
Very similar software build to the TM5502HD & 5302HD these receivers can store 16 & 32 APSK in it's found transponders but are unable to resolve these transmissions.
Some of the satellite receiver's atm that can resolve these transmission,
http://опенбокс.рф/category/openbox-sx6-hd.html
HZ914 Multistream Satellite Receiver - Product - Newtec
..Openbox SX has a great tuner. best I ever tested.
It beats also F15
But, It has a very important bug regarding motorized dish. when you switch from a satellite position to another the receiver loses signal. sometimes you can solve this problem clicking to disable limit function.
but sometimes it doesn't work anyway and it's pretty frustrating.
blind scan is Amazing, quick and very very accurate
it can catch tp with very low symbol rate
Multistream works fine only with non T2-mi and no PLS variant (10east/4,8east/12,5west) and it will not be implemented
4,8 east position is particularly interesting because of multistream FTA ukrainian channels that shows Champions League and sports like Kanal Ukraine and 2+2 Ukraine ususally encrypted in normal trasmission
same on 12,5 west italian mux (gazzetta tv for english champiosnhip and brazilian League), but in my case it's so interesting because I can watch these channels via terrestrial (I'm Italian)
best regards
The one I ordered from Germany should arrive this friday ...
In light of what you have said ..
I'm wondering if I should allow the box to control my motors ..or just use it on loop through from the F15 ?
btw ..
what is the latest firmware you are using ?
I shall need to check what the box comes installed with when it arrives ..
So ..I will be eager to test this box when it arrives ..
Could someone kindly list a couple of easy targets to aim for that the SX can resolve ...here in the UK ?
Good luck, with the new box, will you be using it on ka/ku/c band or just for the apsk channels?My SX6 has just arrived ..
Will get to play with it over the weekend I hope ..
unpacked to check contents ..
One of those silly 2 pin euro plugs ...but uses classic figure 8 mains connector so easily swapped mains lead..
An HDMI lead ..and a wireless dongle..
A substantial remote with batts ..and a fairly thick manual..
rgds
VS
TBH I will probably use it for frequent scanning and investigation of any interesting looking channels on all three bands ..Good luck, with the new box, will you be using it on ka/ku/c band or just for the apsk channels?
We shall see buddy ..Hope you found Polar Edit Octagon helped you.
Well ..fwiw it is installed ..We shall see buddy ..
Finally navigated to what I hope is the download link ..
As I said ...difficult for me as I dont read russian..
version 0.723 ..
Gotta hope there is the option to set English language one installed..
rgds
VS
...and so ..
if I want to integrate this stb into my system I need to set/edit my V/Gbox already stored sat positions in the box ..not have the box set them for me (as the TM5302 -spit-) did ..
Thus I need a channel editor ..
failing this it will always have to be a slave unit on the loop out of one of my other set top boxes..
and so to my question..
What channel editor(s) are out there that will work with the SX6 ?
Anyone ?
..most references to this box on the web ..are russian ...which doesn't help me a whole lot..
rgds
VS
Just a reminder, the Qviart Receivers are 16APSK (and 32APSK) capable .
We already talk about it , I don't remember the thread)
old of my screnshots;
BBC feed @ 28.2°E
VRT Feed @ 23.5°E
no 32APSK TV screenshots, only one feed reported in C-band but I never found it by myself.
View attachment 83646 View attachment 83647
The openbox is better I think, the tuner is more sensitive, you can get the MIS stream (not with PLS) 16APSK , the blindscan is one of the best available on the market and this tuner can lock very low sr like 115 ks and the software is more frequently updated, you can easyly record ts file on a usb key even UHD streams and play it on your computer.
If you have to buy one of them, do not hesitate: SX6
Many thanks FS, the quickest scanning box I use is the X2 and it locks low SR, no 16ASPK , it does not appear to miss much but its not accurate, but I can live with that, I am after a new box and will go for this, thanks again.
