16e eutlesat help please.
pringle22a
sattelite setup-
Dreambox 500s
Dreambox 7020s
2 X maximum 4 in disecq switches
1 triax78 dish on hotbird 13e
1 televes 60cm on hipasat 30w
1 minidish on astra 19.2e
cabling is all webro wf100 coaxial
computer setup-
amd athlon dual core
NW LONDON
hi everyone.
need help with this installation any info much appreciated.
installed a minidish last weekend to pick up 16e, i am using a single output thompson lnb which came with the dish. when i move my dish i can pick up 28.2e,25.5e,23.5e and astra 19.2e with no problems but 16e is being a real problem to pick up. could it be the lnb which is not good enough i have heard the eutlesat signal is weak? could it be dish size? could it be were i live, ilive in north west london wembley area.
thanks for any help
Try the Albanian channel Als&t on 10956 H 2821 2/3. That should be easily picked up on even a minidish.
If you are hoping to get the DigitAlb channels you will need a bigger dish.
One thing first: wooop wooop Wembley !
what type of minidish have you got zone 1: 50 cm or Zone 2: 60 cm ?
Mark
Doesnt make any difference for the strongest channels - Ive had Als&t on a zone 1 in the past. Not much else off 16E though!
i could get it fine on a zone 2 in london, and according to the footprint 50cm should be fine however i know the zone 1 is something like 48cm ?
Mark
Mark
43cm & 45cm.
_http://raven.co.uk/satellite-products/scorpio.htm
thanks for all the info guys i apreciate it.
i have another dish which is picking up tv cabo on 30 west but cancelled my subscription(to expensive). it is a 60cm dish this should work then? i will be using a twin titanium lnb.:)
all i want is to pick up sic international.:)
60 Cm should be fine if looking at the correct transponder!
And im sure that channel is on 30W ?
Well, there is always 40.5 W, with a slightly larger dish and change of LNB.
_http://www.lyngsat.com/nss806.html
