19.2 and 28.2 on 60cm dish
N
neil mcclary
hi i live in west cornwall will a twin lnb set up for 19.2E and 28.2 E on a 60cm dish work or do i need a bigger dish
Should work Neil, but two LNbs on an 80cm would probably be more stable in bad weather conditions.
If you go you go to an 80cm dish then you can also stick an LNB on for Hotbird as well.
N
neil mcclary
Hi thanks all for the advice. Do you know were i can get a bracket to do this. all the best neil
N
neil mcclary
O
Old Fred
Buy the LNB bracket WITH the dish. Although you can get a "universal fitting" bracket, they are pigs to fit and twice the price. Try a search for "LNB bracket kit" or similar.
Fred
Here's one , or here, or here for the specialist Visiosat dish and multi LNB holder
