packetstormer
- 1.1m Triax dish, TM2300 motor. 2 x DM800HD, 1 DM500, 2 x Sly HD. 1 60cm fixed (Astra 2D).
- Ireland
So happy with my DM800 I went and got another one for another room. I flashed Nabio BH12 on to the new one and changed its hostname to DM800SR. I then configured the NIC to manual IP. Then, MADNESS:
Firstly, my existing DM800 started to breakup the Sly signals, stopping every 2-3 mins for about 1 min.
Secondly, for some weird reason whenever one box is up on the LAN the other one can't be contacted!
If I shutdown one box, the other works perfectly.
I thought this might be an ARP problem on my switch, as the hostnames were breifly the same, but I cleared the cache there.
Has anyone ever come across this? Anyone have 2 DM800's on the same LAN working against a CCcam share? BTW, the second on I never even put CCcam onto so it couldn't be that
