2 Twin LNB Set Up Help Required Please
dbaileyuk
Dreambox 7025
Dreambox 8000HD
42" Panasonic Plasma
Sky HD Box
North West UK
Could you please tell me how to set my 8000 up to work with 2 dual LNBs
I have one at 19 degrees ( the main one ) the other is at 13 degrees.
I have taken one lead off each lnb to one disecq switch, 19 deg goes to A
13 deg. goes to B
I have done the same configuration with the other disecq switch.
The outputs connected to the tuners on the 8000.
If that is correct how do I set the 8000 up to work ?
Are the settings done in the, Setup > Service Searching > Tuner Configuration
panel ? or there a bit more to it than that ?
I am running Black Hole.
you have to setup the tuner config in the box , tuner a and tuner b , there are several options , advanced , motorized single.
i got mine on advanced because i use 8 twin lnb's connected to the box
then you have to input the ports of the switch to to satellite it's connected to.
just a screenshot added to see how it's setup , you must set the lnb aswell example mine ( third lnd is the astra 19,2 )
Thanks mick666,
I will have another look at it and see which settings will work
