satlearner
- Jan 5, 2009
- Age
- 53
Deltech Bravia STB with USB HDD
Deltech DreamGame STB with USB HDD
1.8mtr mesh dish (C) - will be removing soon
2.4 mtr mesh dish with 24 inch Actuator (C & Ku) (currently installing)
90cm solid dish fixed (Ku) - will be removing soon
120cm soli
- South Africa - GP
Hi all,
I am currently installing a 2,4mtr dish with a 24 inch actuator and V-Box and based in South Africa. I have been reading many posts and have a few questions....any assistance would be welcome.
1) I need to setup an inclination of 36deg and a declination of 4deg.....lat is 26,2Deg.
My question is what do i set first....if I set the inclination to 36deg, then place the angle finder on the declination arm, reduce the angle to 32 deg.... wil this work or do I set the inclination to 40deg and then the declination reduced to 36deg?
2) LNB adjustment....now everything I read mentions not to stand in front of the dish when setting the LNB....okay, this is understandable, but seeing that I am only 1,6mtr tall and the dish diameter is 2,4mtr, how do i get this right.....I am using a C/Ku LNB and have inserted a perspex disc into the throat as well....it would be a nightmare to rotate the LNB, tighten the setscrew, move away and then check the signal status....can anyone help with this one. I have a Satlook Micro Meter available to set the LNB.
3) I envisage tracking from 78,5E to 22W.....which sat should i really be pionting at when making the initial settings to the dish.
Thanking you in advance
satlearner
satlearner
