Would anybody please know if it is still possible to buy 36 volt 4 core dish motor cable which has two thin cores for the pulse signal and two thicker cores for the current?
I think that there might be a sheilding braid around it all or individual shielding on each of the 4 cores but I would need to pull out the TV unit and boxes to get to the back of the positioner to check about the shielding.
I have searched around quite a bit for some of this without any luck. The cable I am using at the moment was originally part of a flat ribbon style cable that was used on motorised dishes back in the "analogue only" days when 36 volt positioners were dominant. The flat ribbon cable used to comprise one section for the LNB, one section for the polariser and one section for the positioner. It is the 36 volt positioner cable that I am looking for.
Regards
Regards
