42e signal problem - TV8
Shouldn't do, it's on the West beam, although a low s/rate. What size dish do you have and are all other channels okay?
am i doing the search right?
I cant find 11.870 v
I was at first interested on italian channels as i am italian, but all i care is the football so would be good to get that channel
thanks for yor support
Thread split to dish set up section.
Settings look okay although no signal. Are you set up for Turksat 42e?
Do you get ANY of the other 42E channels? If not what channels are you actually getting - list half a dozen you can actually see
What sort of dish do you have? Fixed or motorised?
the dish is fixed, no from the search i don't get any channels, I can get all the italian channels from the hotbird 13, so Rai 1 -2 -3 Italia 1, Canale 5, Rete 4, then i get euronews and loads of italians
I
You need a fixed dish on 42e for the aforementioned channel or 7e with a digiturk package.
I
Your dish is pointing at 13E.
You need another one :D
