aerialview
- 80cm motorized. Diablo 2.3 lite cam with cas3 interface.
- Lancashire
Having minor problems with 5x16 multiswitch system with direct burrial cable over an area of say 1/2 a football pitch.
At the business end when I test out it seems to be 100% working. UHF signal strength, perfect. Sat signal 100% on astra 1 and 2. Powers FTA box and seems to work.
When a sky branded box connects to the system it gives me the dreaded 'no signal being rec'. However I did manage to pick up the radio stations and BBC2. Time and date worked fine, even the listings came up, so something was working. On the services, signal test, as I remember it came up with a very small strength bar and little quality. The network id seemed different it was 7d 'something I think', one Ive never seen before.
My only thinking that its not the dish in the wrong place is that the FTA box seems to work great, showing full strength for both astra birds.
Something is not quite right.
I hope this sounds perfectly clear to somebody.
Help required.
AV
Help required.
AV
