6 LNBs and only 2x 4-way Diseqc switches - How?
H.Rule
Technomate TM-5200D USB Super+,
Technomate TM-2100A H-H DiSEqC motor,
Gibertini 1.2m dish,
Inverto Black Ultra LNB
North London
I have an odd question (perhaps!) to ask.
I have two dishes. On dish 1 have 3 lnbs on a multiblock bracket, going through a 4-way Diseqc switch to the receiver. It works well.
Dish 2 was on a motor which has packed up, and rather than replace it I'm going to put another couple of LNBs on it - I have a couple of old spare LNBs, a 4-way switch and a small multi bracket, so it'll not cost anything.
Problem is that if I do this, I'll have feeds from 6 LNBs, but only 2x 4-way switches. Is there any way of getting all 6 feeds to the receiver using the 2x 4-ways, or will I need a bigger switch, perhaps an 8-way? I'm having a little difficulty finding one which doesn't have to be sent from China or Hong Kong, and those I have seen seem to have a bigger insertion loss than the 4-ways.
Thanks.
its stange that you only have a chines made diseqe
dont you have a sat store selling SPAUN or ATEC product
6 years ago i used SPAUN switch i think its F411 with dreambox 600 copy
it conects 2 diseqe c unit together to one output to dreambox
the two diseq was cheap unreliabel chinies made only 1 $ each
but it wored with no big proplems
later i tried 1 X 8 ATEC diseqe c
there was loss in signal on week transporder on ASTRA 1
now i use 1 X 16 diseqe c ATEC with VU+ DUO
the signal is better and more stabel much of the day
the 1X16 diseqec is much more expinsive than 1X8 in egypt
i think it must be the same in UK
i am realy not in a position to advice you . its completly difrent in egypt
but i think if you in the sat coverage beam you do not need an expensive diseqe . any brand will do fine
if you try to recive a week signal or you are far from the sat beam thin you have to conseder the other options .
you might not beneft from my reply becuse of the loction and the qualaty of goods in europ compared with what we have in egypt
You need a two way uncommitted switch to connect between the two 4 way diseqc 1.0 switches.
Or you could just get an 8 way diseqc 1.1 switch, I used a couple recently, emp centauri, that I got from radtv, one of the site sponsors.
Lads I know this is a different question but can you split a fixed dish and diseqc motor into one cable. And can I use a switch and how would it work cuz my big dish is fixed at 1west and and and then I have a triax and motor doing the rest
Hi Robbo
Does this mean taking the output from each switch into a 2-way uncommited switch, and how do I find one of these beasts? :confused:
Might just be easier (and probably more expensive!) to go with the 8-way.
Thanks.
I'd go down the multiport diseq 1.1 switch route ..
Assuming you can find an uncomitted 2 way switch ...you'll end up paying almost ..if not as much ...as one of these :-
search ebay item
290673595688
Gecen GD-81A 8x1 DiSEqC1.1 Satellite FTA TV LNB Switch
Cheap enough at about £11 including postage ..and they work just fine ..passing motor control ...or fixed diseqc commands..
rgds
VS
Now that is cheap, pity about the possible 4 week wait for it though, but still very good value. Not had chance to check whether motor commands would pass though the emp-centauri one, I must give it a go, i have one in my van somewhere.
Hi Robbo
Well ...the Gaecen ...definately passes usals diseqc 1.3 ...and vbox diseqc 1.2 commands ...and the insertion loss isn't bad either ..
I use one in my system ...the only thing is ..to make sure the receiver supports disqec 1.1 first ...or its a waste of dosh ..
rgds
VS
search ebay item
290673595688
rgds
VS
Yea, was just trying to get away with what I had already but £11 won't break the bank - just ordered one. It's the wait that gets me! ;)
So what exactly is an uncommitted 2-way switch? I'm thinking it's just a 2 into 1 switch but am probably wrong. And would a receiver need to specifically support it? I'm using a Technomate TM5200.
Its a bit like a 2 port diseqc switch ...but is uncommited ..ie the receiver addresses and switches it first ..then passes on to switch either the left hand 4 port diseqc switch ..or right hand one ..
Operating much like a manual A/B switch ...only under receiver menu control.
Important that you first checked that your receiver supports disqc 1.1 (multiport switches) ....or you _will_ be very dissappointed
..not knowing the receiver ..I can't comment..
rgds
VS
Can anyone tell me of I can have a fixed dish and diseqc motor into one cable
Yes ...using the same switch ....but again ..I stress ...make sure the set top box supports diseqc 1.1 first
rgds
VS
rgds
VS
Yep it does support disqc 1.1 (and 1.0). What would I Google to find one of these?
Sorry for the questions - this is a fairly new area for me.
Just google Diseqc uncomitted switch ....but you've already ordered one ?....so why go try and find a 2 port ...now you have ordered an 8 ?.....
..The more switches you chain ..the greater the losses ..
Better to go with the single 8 port switch.
rgds
VS
rgds
VS
It's just curiousity now. But if the 8-way's not enough!... ;)
Thanks for the help! :)
An 8 way switch ishould be plenty, as you can add 4 way 1.0 diseqcs to each input, giving you a total of 32 inputs.
Have done it to 1 port of the emp. Receiver must support 1.0 and 1.1 diseqc.
Can't ever see me needing more than 8. Unless I learn Arabic and German! ;)
