Vipersan
Emmett Browns Ghost
- IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Hi friends..
Finally got round to investigating this meter ..the 600HD pro ..bought off ebay some months ago ..
It appears to work well ..and solidly built ..but as usual ..support is difficult to find..
What I need really is a UK database for it ..
Failing that ..
I'll have to create one..
It appears to come set up for someone living in Moscow.
At least the local sats stored would indicate that.
So It does have facility to dump the meters contents to usb ...which is a start.
I assume this file could be edited in the absence of a UK based database ..then uploaded back to the meter.
The format is (.ABS)..
Can anyone help with either links to suitable databases/support ?
If not the a suitable editor.
No software came with the meter ..so I assume its probably (hopefully) standard.
rgds
..btw the sticker on it would indicate it was made by ..or at least commissioned by..a company called 'Golden Media of Germany'
VS
Failing that ..
rgds
VS
