Hi, just joined (well, joined last year, but never did much). Impressed by the discussions. But now I need help!
I have read a good few threads about long cabling and I am now pretty worried as my cable run is a lot more than the ones I have read about. My run is about 100 metres
In Dublin. I have a Technomate 6900 Super Combo, a 80cm motorised dish for Hotbird 13E, Astra 19E and Astra 28. Worked fine, but had to move the dish. Now on roof of a Georgian building, runs down (in conduit) to under ground, through 50 metre pipe which has other cables like fire alarm, cctv and burglar alarm, then into other building.
I think I aligned the dish correctly so that it moves on the right plane for these three satellites.
Got average of 74% signal quality for the three sats when attached TM to the dish directly. At other end of cable, however, only BBC World and other BBC channels are coming through. Also seems that the motorised thing is iffy with this length - sometimes it moves to the desired sat, but most channels are "Bad Signal". Signal loss is pretty bad it seems to me.
OK, have to admit, as I was doing one bit of chasing, the wire kinked so may have got damaged.
It is my problem (!) and I am determined to solve it especially after so many hours of chasing cables. So, some advice would be greatly appreciated.
Pointers & Questions:
1) the cable I have seems pretty good: hard copper core surrounded by solid white plastic then foil sheet then copper interwoven wire then outer plastic cover. I will check the resistance on the wire.
2) 80cm dish. Do you think I should go to 1 metre or even 1.2? Any recommended brands or are they pretty much the same?
3) Amplifiers. I know they amplify everything (signal and its noise) but perhaps I need that. Any suggestions on which type I could try. Also, does amplification kill the motorised control of the dish (not that I have much) from the TM?
4) Do you have advice on LNBs - I guess that I must squeeze out the best from the LNB and the dish if any decent signal is to survive that length of cable....
Thanks, Barso.
Thanks, Barso.
