Addons download problem
Kingman
Suffolk, Englnad
Hi
trying auto download of Cams and keys via both blue key on Gemini and Control panel via Hydra. Having trouble with both these functions.
Blue Key Scrren - Hangs at downloads (doesnt display downloads available)
Hydra Control Panel - Cant get this to display - press green button nothing happen.
All comms set-up is Ok, Dreambox is connected via router and is working fine with FWZ and edit on the PC. Internet etc is OK in the house
Plese help
Kingman
Havent used the hydra in a long time, but I think there is a new url you have to copy and paste in. What Gemeni version are you using. Blue button should work with them. Check your firewall on your computer, or switch it off and retry.
you could also check in communication set up,that your ip address and gateway are all correct
Havent used Hydra for a while as there is no support for this image so that may be the problem, as for gemini working fine here as are pli and dbbrothers!
Did you solve your problem, Kingman? As I'm having exactly the same problem with PLI Diamond and Davinci 5.4 on a usb memorry stick. Gemini 2.70 is the only image that allows me to access internet, download plugins on usb. Hopefully you can help me, if all is well on your side now.
Regards, Tore567
Hydra CP and downloads still working OK, 10 March 2006.
Check the IP address setting on your Dreambox as this may be your problem.
New Hydra Panels out for the 7000,5620 & 500 models. See key sites.
All OK now using Hydra.
Not sure what the issue was, think it was possibly the channel I was on accessing the blue button or maybe it was my internet connection. Think the Gemini issue was because there server was down.
I now have the confidence to use FTP to download manually so things must be getting better!!
Amazing how easy everything seems once you know how, maks the perseverence worth while
Thanks to all for help
Kingman
